Home > General > Transmission Fault & HDC Unavailable, suspension lowers |
Before any battery test can be done it needs to be properly "off"
Mon Nov 05 2012 4:16pm |
pa81 Member Since: 05 Nov 2012 Location: Hillingdon Posts: 9 |
Thanks, yes I have also checked the tail light bulbs, all working fine. |
Mon Nov 05 2012 4:21pm |
Hmmm.. the trouble with our wonderful cars is they flash up the HDC fault at virtually any oportunity and the problem might not be suspension related at all... equally it couold be a failing compressor.
Mon Nov 05 2012 4:24pm |
Alternatively you could do a running engine volt check?
Mon Nov 05 2012 4:29pm |
Thanks I'm going to take it to a local garage now and see if they can run the battery test - hopefully they will be able to do both.
Mon Nov 05 2012 4:36pm |
£50 is about right, mine charge £80
Mon Nov 05 2012 4:38pm |
That is handy, I might have to look into buying one. Any advise? Roughly how much do they cost and are they easy enough to operate |
Mon Nov 05 2012 4:51pm |
Mine is part of my BAS re-map interface
Mon Nov 05 2012 5:17pm |
paying to read fault codes.
Mon Nov 05 2012 5:29pm |
Thanks - I will check it out!
Mon Nov 05 2012 5:34pm |
lee157 Member Since: 07 May 2010 Location: in the middle Posts: 19 |
Hi PA81,
Mon Nov 05 2012 5:53pm |
Thanks Lee, very helpful. This may sound like a basic question but where is the foot brake switch located? |
Tue Nov 06 2012 10:27am |
Also switch the screen over to the view with the transmission and suspension / diff locks
Tue Nov 06 2012 10:59am |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 |
There's a few other things that indicate a battery on it's way out such as the SatNav going off on starting the engine briefly. Does yours do that? Have a search on here to see some of the other indicators.
Tue Nov 06 2012 11:01am |
