Home > Maintenance & Modifications > Fitted de-cat pipe :) :) :) |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Be careful decatting - could result in an MOT fail these days. 2012 SDV6 - it's missing a couple of cylinders
Fri Nov 02 2012 3:35pm |
saimans Member Since: 22 Oct 2012 Location: UK Posts: 46 |
Once heard 4.2 SC with a non standard exhaust and what an awesome sound that made. Couldn't belive it when I saw it was RR Sport. Apparently the guy just had the internals removed from the existing mufflers. |
Fri Nov 02 2012 5:25pm |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 697 |
How does it sound?i cud fancy doing this Java black 2006 |
Fri Nov 02 2012 9:22pm |
m22 gtr Member Since: 18 Apr 2011 Location: edinburgh Posts: 399 |
Think I'm going to fit one, is there any engine lights on the dash that come on, take it car doesn't need mapped once fitted? Is there big difference in noise? |
Sat Nov 03 2012 9:55am |
cozzyrick Member Since: 03 Nov 2012 Location: staffordshire Posts: 17 |
so what exactly did you have to remove to fit the new pipe ? and any warning lights on dash since ? |
Sat Nov 03 2012 3:50pm |
vic_ster51 Member Since: 21 Sep 2012 Location: east anglia Posts: 28 |
hi no warning lights etc... you can hear it abit more in cab slight wine as 1st off when radio off!
Sat Nov 03 2012 6:44pm |
there is no wires or sensors etc attached to cat pipe... so you wouldnt get any warning lights anyway
Sat Nov 03 2012 6:46pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
We have been through this more times than I care to remember. A decat on a Diesel WILL NOT be a cause for an MOT fail. If it does fail, kindly refer him to his MOT tester's manual, or find another MOT station |
Sat Nov 03 2012 9:58pm |
Thanks for getting back to me and now I will have fun fitting mine on Tuesday lol and I also went for the uprated silicon pipe that goes from turbo to inter cooler as they recommend swapping then as they are prone to wear and also sucking in under high boost from remap |
Sat Nov 03 2012 11:19pm |
Never heard that before on a D3. The intake pipe is a rigid plastic pipe, attached to a steel pipe, with only a 3 inch long rubber pipe, that I have never seen split before...
Sun Nov 04 2012 8:30am |
yes disco mike the pipe I have brought is long so that must be the one like you say from intercooler to intake and the tuning shop said that they tend to suck in under load. |
Sun Nov 04 2012 1:18pm |
forgot to ask what the procedure is when jacking the vehicle up as unfortunately ive got to do it on my back and not on ramps |
Sun Nov 04 2012 3:12pm |
C20MEO Member Since: 29 Jul 2013 Location: glasgow Posts: 3 |
hi do you have a video of this as i would really like to hear what your rrs sounds like now ????????? |
Tue Nov 19 2013 3:12pm |
It sounds almost the same as standard. A little bit throatier, a bit more turbo whistle, but makes little to no real difference to the noise |
Tue Nov 19 2013 3:14pm |
