Home > Technical > Cruise control
pipework
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Cruise control
I have read about problems with ACC, but would this stop the cruise control working all together? The message "cruise control not avaliable" appears on the screen.
Thanks Ron
Post #360387 Mon Oct 22 2012 9:52am
moi7i
United Kingdom 2006 Range Rover Sport TDV6 HSE Tonga Green
I am sorry I can not help you but while we are talking cruise control has anyone had my problem or know how to sort it out.
Sometimes when I start a journey the cruise control will not come on when I try to op. it so I have to stop switch engine off and start engine again it will work for the rest of journey although sometimes it stops working again. If it stops working on a motorway I have to put RR in neutral while travelling at say 50 mph turn engine off and then restart and it works again. Has anyone had this problem or can explain it for me . Thanks for any help
Post #361627 Fri Nov 02 2012 11:23am
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Sorry, you turn the engine off while travelling at 50mph?
Post #361644 Fri Nov 02 2012 4:01pm
moi7i
Yes . If the road is clear in-front and nothing behind and straight into neutral ignition off for say 2 seconds and then restart engine and back into drive. Not that hairy. Have you or any other readers had this problem with cruise control
Post #361647 Fri Nov 02 2012 4:18pm
Shocked
Post #361648 Fri Nov 02 2012 4:19pm
pjb
braver man than me Shocked Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #361650 Fri Nov 02 2012 4:39pm
i would have used the word Stupider instead Rolling Eyes , if that what he's doing his putting his life and others at risk doing so
Post #361652 Fri Nov 02 2012 4:46pm
saimans
Is it such a big no no to turn the ignition off while travelling at speed. Other than the obvious dangers of not being able to take evasive action should the need arise. Would there be any detrimental affect to the vehicle ? Never done it in my Range, but in a previous Audi that kept going into limp mode it was one way to 'reset' it. Trying to pull on and off the hard shoulder, would probably be just as hazardous. Question
Post #361656 Fri Nov 02 2012 5:15pm
+1 Shocked ON THE WAY: BMW F21 M140i
Post #361673 Fri Nov 02 2012 7:22pm
moi7i
Thanks for your comments guys but has anyone got a answer for the cruise control problem
Post #361699 Sat Nov 03 2012 8:31am
