Home > Technical > Number plate bulbs
Superclean
United Kingdom 2007 Range Rover Sport TDV8 HSE Luxury Arctic Frost
Number plate bulbs
Hi guys
Whats style of bulbs are the rear number plate bulbs on the 2007 sport. Its at the workshop so cant check myself. are they 501 or festoon?
Mike Always clean.
Post #361524 Thu Nov 01 2012 12:48pm
Bodsy
Site Sponsor
501 Thumbs Up
W5w also I think they're called. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #361525 Thu Nov 01 2012 12:49pm
Ive put LED's in mine and they look so much better. Thumbs Up
Post #361526 Thu Nov 01 2012 12:54pm
Bodsy
Site Sponsor
It takes 19leds for a disco3 HSE Shocked Shocked Shocked Bodsys Brake Bible
See it HERE
Post #361527 Thu Nov 01 2012 1:10pm
SRE
Spain
So now the plate is illuminated to such a high level that the speed camera's get only a megga white reflection Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #361531 Thu Nov 01 2012 1:32pm
Not quite Whistle But it does look so much clearer and not the dull yellow you sometines see, Merc's also fit led's to their rear plate lights now.
Post #361532 Thu Nov 01 2012 1:45pm
Superclean
Excellent help, update will be starting next week on the sport! Always clean.
Post #361539 Thu Nov 01 2012 2:15pm
Just done mine
Bought a pack of 10 off ebay and did them all barring the front reading lights RRS gone
Post #361542 Thu Nov 01 2012 2:27pm
SRE
Spain
awd man wrote:
Just done mine
Post link Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #361568 Thu Nov 01 2012 5:05pm
http://www.ebay.co.uk/itm/10X-T10-8-SMD-50...OU:GB:3160
Thumbs Up RRS gone
Post #361570 Thu Nov 01 2012 5:11pm
SRE
Spain
Ordered Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #361571 Thu Nov 01 2012 5:42pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Had a look at the ebay link and was woundering if these leds are a good xenon match?
tried alot of different leds and always got some blue green ish lights.... RRS 2006 2.7 HSE
Post #361596 Thu Nov 01 2012 10:18pm
Cupra
ordered 20 thats enough to do all the bulbs ?
Post #361600 Thu Nov 01 2012 10:31pm
The bulbs in awd's link arn't the bulbs for the sports number plate, well not the same as mine, these are the ones in mine i think Wink http://www.ebay.co.uk/itm/C5W-36MM-3-SMD-L...5628513%26
After checking my bulbs since awd's post, i can confirm the bulbs fitted to my motor are the bulbs in awd's post and NOT the ones in this ink. Embarassed
Post #361601 Thu Nov 01 2012 10:33pm
@Ady : I used these for my numberplate bulb replacement Thumbs Up
@RRSNorway: I've got the HIDS4U LED sidelights in mine, and they match the xenons until the xenons warm up (then they look a tad blue'er than the headlights). RRS gone
Post #361615 Fri Nov 02 2012 9:58am
