Home > General > Fuel tank door not locking
hotlatte
2007 Range Rover Sport TDV6 HSE Alaska White
First of Hello to everyone. I have recently joined this forum and hoping to join the range rover community to help, get help and share.
i own Range Rover Sport 2.8 TD HSE 07 registration. Last night after locking the car using the remote out of curiosity i checked if the fuel tank door would lock as it does for most cars and to my surprise it didn't lock.
Bit concerned here as this is a danger and anyone can access and open the fuel cap etc. Could somebody please advise.
Many thanks in advance. Thumbs Up
Post #361556 Thu Nov 01 2012 3:40pm
jonnygo
England 2007 Range Rover Sport TDV8 HSE Java Black
Hello Thumbs Up
I have the same issue I think it will be the fuel door lock solenoid
Theyre about Ģ25/30 TDV8 Java black/Ebony black
Post #361557 Thu Nov 01 2012 3:48pm
hotlatte
jonnygo wrote:
Hello Thumbs Up
Theyre about Ģ25/30
Thanks for the response are the doors not meant to lock along with the rest of the car
Post #361559 Thu Nov 01 2012 3:58pm
jonnygo
Yes it should lock with the car doors. TDV8 Java black/Ebony black
Post #361560 Thu Nov 01 2012 4:01pm
hotlatte
have you had one fitted? does it need to be specific type.
thanks
Post #361561 Thu Nov 01 2012 4:02pm
jonnygo
No mine is rarely left unattended so not too bothered tbh.
I would have thought it would be a land rover part. TDV8 Java black/Ebony black
Post #361562 Thu Nov 01 2012 4:15pm
hotlatte
Yeah i agree- can't believe whether this was a build flaw?
Problem is when we leave cars parked elsewhere its open to risk.
Thanks for your help mate.
Has anyone fixed this issue?
Post #361563 Thu Nov 01 2012 4:17pm
drdelrrs
Before spending too much cash you might want to check its not just a blown fuse
Post #361564 Thu Nov 01 2012 4:21pm
hotlatte
very good point- thank you.
Whats the best way to check the fuses any help will be appreciated
Post #361566 Thu Nov 01 2012 4:49pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
had this fail and fixed-under-warranty on a 57 plate TDV8
Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #361585 Thu Nov 01 2012 8:00pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hi gents.
The locking pin for the tank "door" is controlled via the CAN-Bus system,
so You canīt just check with 12V,and the most common fault is that the pin,
that should engage the "door" is broken.
I trhink that the most common scenario is:
"Car locked, "door" not closed completely, gives "door" a "gentle" shove to close it..."
Result: Pin off..
If You lock the car, whilst checking in the hole where the pin should emerge,
and You just see the pin coming to the rim of the hole, then the pin is broken,
and You have to get a new actuator.
They are not expensive, and easy to change, situated behind the inner
moulding of the luggagecompartment.
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #361589 Thu Nov 01 2012 8:29pm
hotlatte
Maxarn58 wrote:
Hi gents.
Result: Pin off..
Best regards
Uffe
Thanks - I will try this out tomorrow
Post #361680 Fri Nov 02 2012 9:24pm
