Home > General > Oh FFS... |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
I always use Sean at http://www.sb-engineering.com/ he is competative and offers a quick turnaround |
Thu Oct 25 2012 9:00pm |
Flashpilot Member Since: 15 Oct 2012 Location: Global....a lot of the time Posts: 38 |
Surprise surprise!!
Tue Oct 30 2012 7:25am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
switches aren't switches any more (in the sense of completing the lighting circuit to make the bulb illuminate).. they're just "communicators" that tell the ECU via the CAMBUS (or equiv) that you have moved the stalk. Then the ECU tells the light, again via the CAMBUS, to flash.
Tue Oct 30 2012 9:05am |
You're right....however, in this case, the "switch" will do as it is told with some wiggling....so i think it is the culprit. Will get it looked at in 30 mins....just off to Lancasters to have the clunk AND indicator issue looked at!
Tue Oct 30 2012 9:18am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Good luck with it FP - looking forward to your next post !! FF 4.4 V8 Soooo looking forward to this bad boy
Tue Oct 30 2012 10:14am |
So....switch seems to be the culprit re indicator....waiting on price.
Tue Oct 30 2012 2:50pm |
Nigex4x4 Member Since: 17 Jul 2014 Location: scarborough Posts: 22 |
At the risk of becoming some sort of Pariah and not knowing how much you paid for your car I'm forced to suggest that we all need to be reasonable.
Tue Dec 16 2014 10:47pm |
