Home > Wheels & Tyres > Profiles
Thumbs Up ON THE WAY: BMW F21 M140i
Post #361234 Mon Oct 29 2012 5:23pm
oldcro
Scotland
As the speedometer reading is calculated from wheel rotation how can it always be accurate? Considering the tyres can loose 6mm from new to still legal the distance travelled varies greatly per measured revolution.
Of course you could try steel rimmed wheels like a train, or throwing out a concrete block with a long knotted rope attached and check time against number of knots flying through your hand. Both somewhat impractical so what we have does a fairly good job at what they do, bearing in mind speed limits are as their name suggests maximum limits to remain under and not targets to aim for. Whistle
Post #361236 Mon Oct 29 2012 7:01pm
Exactly - tyre wear is part of the tolerance built in to the allowed inaccuracy. 2012 SDV6 - it's missing a couple of cylinders
Post #361239 Mon Oct 29 2012 7:20pm
Tre4
2011 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Thanks for the tips.
Looking at be calculators, the 255/45 is the biggest recommended profile on a 20" rim.
I guess what's best to remember is that the profile figure is a percentage if the tyre width, so a 45 on a 275 is more rubber than a 45 on a 255.
I think I'll look around to see what looks good Thumbs Up
Post #361256 Mon Oct 29 2012 11:56pm
Dingoz
Australia 2005 Range Rover Sport 4.4 V8 S Bonatti Grey
Many many years ago in Australia, the RTA (road traffic authority) had cars driving around with large speedo's on their boot lids. When you see them, you could simply follow them and get an idea of the accuracy of you speedo. It was all too easy back then, now they prefer to collect revenue RRS '05 4.4 Bonatti Gray Black Leather
Discovery S1 3.9 manual with extractors
Mitsubishi Starion (ex group e production car)
Post #361258 Tue Oct 30 2012 1:03am
Tre4
Oops! On re-reading the manual, it states winter tyre size of 255/50/20 and not '45' in the first post Embarassed
So;
Normal 275/40/20 gives profile of 110mm (4.33 in) (40% of 275)
Recommended winter 255/50/20 gives 127.5mm (5.01 in) (50% of 255)
Normal diameter = 20"+8.66"= 28.66"
Winter diameter = 20"+10" = 30"
Circumference = Pi x d
norm = 89.99"
Winter = 94.2"
1 mile is 63,360 inches;
In a mile a normal tyre would rotate 704 times A winter tyre would rotate 673 times.
With the difference being 31 revs per mile, the winter tyres would travel 133 inches less per mile and therefore under read on the speedo by 0.02%
I think Confused
Is it all really just a simple matter of how much rubber you can fit without it rubbing on the bodywork, rather than the technical side?
Post #362140 Tue Nov 06 2012 4:42pm
mse
Or you just enter your tyre size and the computer resets...im sure that options in there somewhere (diagnostic kit not the bit you see) Mike
2014 Facelift Discovery
Post #362146 Tue Nov 06 2012 4:56pm
