Home > Faults & Fixes > 05 sport egr problem |
For your year, blanking the valves is perfectly fine. Although the limp home mode sounds more like fuel problem. Have you fitted a cheap fuel filter to it instead of the LR one. This has proven to cause many problems like yours in the past.
Sun Oct 28 2012 6:37pm |
eddercloon Member Since: 28 Oct 2012 Location: longford Posts: 2 |
Next week i will have a new filter and oil change done, and see if this will fix problem, i will find out what fault codes are showing also and report back later, the car was serviced in a land rover place not a main dealer, i was wondering what type of oil they used was it correct or not and if not maybe the filter was not correct also.
Sun Oct 28 2012 8:03pm |
It might be an EGR cooler that is leaking and causing the premature EGR failure, i had one replaced on my 06 plate sport with only 51000 miles on the clock, |
Sun Oct 28 2012 8:13pm |
