Home > General > Memory positions on seats and mirrors
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
You do Mr. Green
The knobs on the left hand side not the right, just checked today.
Nik
FF1078 wrote:
Well you learn something new every day Exclamation
 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #360903 Thu Oct 25 2012 6:41pm
V88ABA
2007 Range Rover Sport Supercharged Java Black
All I have on my left side is the indicator stick, the voice command thingy and that's it????
Post #360915 Thu Oct 25 2012 8:04pm
Nik
Picture of the switch on my car....
Nik 2015 Golf R DSG
Post #360924 Thu Oct 25 2012 8:47pm
V88ABA
I don't have that!? Pretty sure I would as have a s/c with just about every extra going!? I'm gutted!
Post #360925 Thu Oct 25 2012 8:55pm
Nik
I have it in the off position so never use it anyway, just another battery sapper along with welcome home lights........
Nik 2015 Golf R DSG
Post #360928 Thu Oct 25 2012 9:01pm
Pufftmw
I looked for the knob & found it missing in my car Sad
However, I was looking through Settings (on the info button) whilst stuck in traffic this morning and found "Lazy Entry" as one of them. I have turned it on and will see what happens...
MY07 HSE
Post #361176 Mon Oct 29 2012 11:09am
Cheney Jawa
I have my knob set to auto/lazy entry but when it works the steering wheel & seat only move a tiny little bit Confused
Can anyone confirm whether the steering wheel & seat should go quite a way in/up/back.
I'm not really fussed tbh i'd just like to know whether it's another fault or not. Shocked Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #361554 Thu Nov 01 2012 2:33pm
mse
It depends where its set to begin with Mike
2014 Facelift Discovery
Post #361574 Thu Nov 01 2012 5:19pm
Lazy entry and auto steering adjustment are apparently 2 seperate things
Lazy entry works off the fob,and is enabled/disabled via the stalk computer
Auto steering column adjustment is operated via the ignition on/off/key removal, and is enabled/disabled via the knob on the left hand side of the column.
Thumbs Up RRS gone
Post #361575 Thu Nov 01 2012 5:25pm
mse
On the new ones the steering wheel moves out of the way with the seat to allow easier entry.
The auto adjustment knob stops that on the steering wheel and the menu stops the seat and steering wheel Mike
Post #361580 Thu Nov 01 2012 5:50pm
Cheney Jawa
I sort of thought after my post that they were two completely different things!!
However i still have the issue with the "Whatever it's called where the steering wheel & seat adjusts automatically to aid easier entry/exit to the vehicle"!!, in as much as the steering wheel & seat hardly move.
mse eluded to where it is 'set' to begin with, how is it 'set'?
Smile Smile Confused Confused Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #361581 Thu Nov 01 2012 5:51pm
mse
Its not set as such - it moves rearwards and down for the seat and upwards on the wheel (from memory) to maximise the gap
For you its either on or off...if there isnt far for the seat to move, it wont Mike
Post #361582 Thu Nov 01 2012 6:17pm
lee551247
My switch on the steering column is set to auto and i also have lazy entry enabled and most of the time when you unlock it and get in the seat and steering move when the hey is inserted into the ignition but on the odd occasion when it is unlocked the seat and steering move straight away before i get in! Also sometimes it doesnt move all the way to the memory position and you have to finish it off by pressing the mem button 1......It definitely seems as though it has a mind of its own! Confused
Post #361616 Fri Nov 02 2012 9:00am
CeeJay4Fun
Sweden 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I think that it is dependent on which setting (Memory seat) is used. My lady is a lot shorter and it both seat and steering wheel moves a lot for her... I am taller (182cm) and only steering wheel moves for me.
I think the seat lowers and also goes backwards for the short lady! RRS 2010 TDV6 HSE Santorini Black
Volvo V60R D5 2011 Black
Jaguar XKR Cab 2002 Blue
Polaris Ranger 800HD Green
John Deere 6430 Premium 2009 IVT, GPS, Very green
Volvo L30B Pro 2012 Yellow
Post #361925 Mon Nov 05 2012 1:45pm
