Home > Maintenance & Modifications > permanently lowering my RR sport TDV6 2006.
Franko
Scotland 2006 Range Rover Sport Supercharged Fuji White
Hi folks
I have the button which lowers the car, keeps it at driving level and raises it to off road height for extra clearance.
I like the idea of keeping it lowered. The car automatically raises to the middle setting when I reach a speed of 30mph. I lower it all the time as it looks meaner and a bit more sporty but I've been told if I continue to lower and raise as much as I'm doing then the airbags will start to cause me problems.
Is there anyway the car can stay lowered? Or is it not good for the driving etc. Please if you can help I would be very grateful.
Franko Range Rover Sport Supercharged 2006 plate
Post #360114 Fri Oct 19 2012 10:30am
Ste Sleds
2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Re: permanently lowering my RR sport TDV6 2006.
Franko wrote:
Hi folks
Franko
Do you Not find the ride is terrible with it lowered, don't think I would like to travel far with it like that.
Post #360115 Fri Oct 19 2012 10:41am
Rudskibaliblu
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
You can buy a plug in module that keeps it at s set height, not sure think Awd mans got one fitted. Sure he will be along soon to give you the details Thumbs Up Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Here 110 black edition defender.
Post #360118 Fri Oct 19 2012 11:12am
mlines
http://www.gap-diagnostic.com/ then buy it from Britpart 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #360120 Fri Oct 19 2012 11:56am
V88ABA
2007 Range Rover Sport Supercharged Java Black
I'm selling one if you want one. Gap diagnostic. Plug in and play! Lowers by anything upto 30mm
Post #360121 Fri Oct 19 2012 11:59am
As above Thumbs Up
GAP EASControl (you tube videos if you search EAScontrol) Thumbs Up
Anything more than 25mm will greatly effect the ride quality, mine's been on -22mm for 12 months now and it's great, you do however lose the access height selection with anything more than 17mm? (Hits the bump stops and goes into extended height) RRS gone
Post #360122 Fri Oct 19 2012 12:07pm
Franko
How much are you looking to get for it? And does the device still allow me to use the lowering and raise buttons to set heights?
For example if I lowered it to 25m then how would I get it back to normal road height if I wanted to use it for a longer journey? And then do I need to plug in again to get back to my 25m or do I just use the button in the centre console?
Apologies for the questions its my first RR venture.
Thanks. Range Rover Sport Supercharged 2006 plate
Post #360160 Fri Oct 19 2012 3:57pm
V88ABA
When it's plugged in you manually select hight by mm.
As long as you haven't lowered it by more than 18mm you can still use access mode. Obviously however low it's set you can always use off road mode. If you want to set it to original settings you have to plug it in and change by mm again. What it does is basically hack into the system and reset the calibration so the vehicle thinks whatever you've lowered it by is the standard height if that makes sense.
Post #360196 Fri Oct 19 2012 9:50pm
Franko
Ok I get you! Sounds easy. Is there any negatives with it? Or faults that may occur by doing this?
And how much are you looking for?
Thank Range Rover Sport Supercharged 2006 plate
Post #360214 Sat Oct 20 2012 8:51am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Thank
Franko,
I've been running the EAS/IID Tool lowered suspension (-15mm) now for quite sometime and have had no fault codes etc occur.
However, I will say going from standard height with 285/50R20 tires to -15mm ride height and 285/35R22 I have noticed the ride firm up significantly, however, I have to say it's not offensive, even on the poor roads we have here.
Regards
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #360227 Sat Oct 20 2012 12:38pm
kml4ever
Turkey 2007 Range Rover Sport TDV6 HSE Lugano Teal
Lowermyairride is the best i had it and works great but as awdman says you loose the acces height but it worth for it and very cheap KML4EVER
Post #360276 Sat Oct 20 2012 9:03pm
Bodsy
Site Sponsor
Just don't forget to get your wheels re-aligned or you'll be scrubbing off a new set of tyres in next to no time. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #360279 Sat Oct 20 2012 10:21pm
In addition, the EASControl unit takes a backup of the vehicles standard ride height settings prior to any adjustment by you.
So you can return to standard at any time Thumbs Up
Wheel alignment def advised, my rear toyos were showing wear on the inside after 8k's worth of lowered ride height RRS gone
Post #360366 Mon Oct 22 2012 8:01am
saimans
I had the adjustable links from lowermyairride it did what it was supposed to do. I set it to the lowest and OMG what a stupidly hard ride. It looked fab, but was totally undriveable even a leaf in the road had you quaking. I got rid of them in the end as it messes about with the ride height settings too much and was a PITA.
Post #360443 Mon Oct 22 2012 2:56pm
Stryke
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Recently bought the IIDTool and lowered my FFRR. No faults, car looks a lot nicer now, especially with the 22" wheels.
Haven't noticed a difference in the ride to be honest.
I would go for the IIDTool over anything else, very useful, you can turn on some features in the back end, read faults, mess around with the suspension. I think I paid 275. Good to have.
Post #360470 Mon Oct 22 2012 5:48pm
