![]() | Home > Technical > How to recover failed RRS in P with EPB on! |
Don't know about taking it out of P but you can manually release the parking brake at least on the pre 2010 models. This thread helped me in releasing the park brake on mine when I destroyed the brake shoes last month (thanks Bob).
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Ok, you prompted me to investigate. I thought that there must be a way.
georgien Member Since: 01 Mar 2018 Location: Mignault Posts: 19 ![]() ![]() |
I need same info for RRS MY 2017, please !! Nik
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
One way to release the EPB you can remove the park brake actuators from the calipers and wind the park brake off manually using torx drive bit.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 315 ![]() ![]() ![]() |
Well every days a learning day😀 I knew about the EPB release but didn’t know you could access it through the cup holder, didn’t know about the park release....do now.
Thanks Col but that was not my question. "If you could not start due to electrical failure how do you get it out of P and disable the handbrake. " Above explanation is about Disco and I am looking for identical solution but for RRS MY17. Thanks for your help Nik Nik RRSport L494 SD4 MY'17 Audi Q5 BMW X3 Audi A6 Mercedes R Volvo XC70 BMW 5 Range Rover Classic UMM Toyota BJ40 |
Not sure about getting it out of Park, but according to the Workshop Manual that is how you release the L494 EBC if you have electrical failure, it is a totally different setup being electrical operation rather than mechanical as the L320/Disco which is as you say what the previous posts and pictures are referring to.
Thanks Col, exactly what I was looking for !
I remember removing the cup holder on my15 & their is a red lever that you can pull,I’m guessing that’s how to take it out of park. Andy.
