Home > In Car Electronics > Help. What bits do I need to fit hands free
Mitchmx
Alright chaps
I have a parrot hands free fitted but don't like it much. I've seen the green and red control stalk forsale and wanted to fit that.
When I press the phone button on the radio it's says no phone fitted.
Apart from the phone stalk what else do I need?
It's a my2006 hse.
Thanks in advance
Mitch. Thumbs Up
Post #359830 Tue Oct 16 2012 8:11am
Bodsy
Site Sponsor
You already have the microphone I assume (do you have voice control button on left side of steering wheel?)
So you will need the telephone pti switchback for the steering wheel, a most cable for the blutooth module (it needs to be then adapted to plumb into the existing most network)
A blutooth module (get the disco4 one as slightly cheaper and much better).
Power from fuse 58 using a piggyback connector, earth to an earth point.
You then need it enabling with a faultmate.
I've fitted a few of these on disco3's. Thumbs Up
Cost for the parts is about £220ish assuming you have the mike and voice control button.
Plus fitting and enablement. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #359839 Tue Oct 16 2012 9:16am
Mitchmx
thanks for the reply.
well i only bought the car last week so not sure whats its got in there but the parrot works ok so i suppose i can use the mic and speaker from that?
yes it dose have the voice control on the left hand side of the wheel.
so the telephone pti switchback is the unit with the red and green buttons?
can i buy the most cable and bluetooth module seprate or is it a kit from lr?
thanks Wink
Post #359857 Tue Oct 16 2012 11:31am
Bodsy
Site Sponsor
You can't use the mic from the parrot, I'm referring to the mic in the overhead console which is linked to the factory fitted voice control button on your steering wheel (assuming you have that)
Telephone pti switch pack is the red/green buttons.
If yo speak to Nick at Yeovil Landrover, he can tell you the parts you need. Tell him I sent you there if you do Thumbs Up
LR don't do a kit as they say you can't retro fit the factory kit.
You need the items I listed before. All gen LR.
Where are you based if you wanted it fitting? (and perhaps some other upgrades...? Wink ) Bodsys Brake Bible
See it HERE
Post #359861 Tue Oct 16 2012 12:09pm
Mitchmx
ok great, ill give them a shout. thanks for that.
im in bristol, looking at your signature i could be tempeted on a few other things. Mr. Green
Post #359877 Tue Oct 16 2012 2:31pm
Bodsy
Site Sponsor
Not a problem Thumbs Up
I have another customer that way, would be good to match the trip up for both of you Thumbs Up Bodsys Brake Bible
See it HERE
Post #359884 Tue Oct 16 2012 3:39pm
