Home > Technical > Brake Problem
rogerpop
2008 Range Rover Sport TDV8 HSE Santorini Black
Brake Problem
I have a 2008/08 tdv8 and have a problem with brakes. On pressing brake pedal it goes half way down before brakes come on. On pumping pedal it only needs pressing a small amount . Its as thou brakes need bleeding. They are not spongy and fluid level has not got low. There are no fluid leaks on system. Any ideas anyone?
Post #359532 Sat Oct 13 2012 4:51pm
Bodsy
Site Sponsor
Possibly your Brake Pedal Switch
Have you had the Brake recall? Does the Brake booster gurgle at all....? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #359546 Sat Oct 13 2012 7:10pm
rogerpop
Thanks for reply, Looked at brake recall but my vin number does not fall into that batch. There is no gurgle noise. I had brake lght switch replaced 6 months ago due to dash lighting up like a xmas tree.
Post #359560 Sat Oct 13 2012 9:43pm
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
Rogerpop, I had a similar problem with mine, pedal got longer and longer travel over a few days, the brakes wouldn't bleed, they wouldn't push fluid through, turned out to be master cylinder shot, the seals had swollen and gone soft. Genuine cyl. was less than 60.00 pounds, good value I thought, hope this helps.
Post #359644 Sun Oct 14 2012 10:51pm
rogerpop
All sorted. It was front nearside wheel bearing. It was not making a noise but on jacking car up to look at brakes noticed rocking movement on wheel in 6 and 12 oclock position. Changed wheel bearing and brakes are now ok. Must have been with bearing going and movement it was pushing pads back a little bit.
Post #363475 Sat Nov 17 2012 6:13pm
shakeapaw
I had my front nearside hub replaced as it was nearly hanging off due to the shot bearing, but i never suffered any brake issues, still as long as its fixed 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #363481 Sat Nov 17 2012 6:49pm
