Home > Technical > Pumping noise when the car has the engine turned off
lee551247
What is the pumping noise coming from the front of the engine by drivers wheel when the engine is shut off, it only lasts about 5 seconds??
Thanks
Lee
Post #359268 Wed Oct 10 2012 8:48pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Does it sound like a valve opening and closing ?
If so EGR valve cycling, completely normal. 2009 3.6 TDV8 HSE Santorini Black
Post #359273 Wed Oct 10 2012 9:55pm
lee551247
It makes a slight squeak but it does sound like something opening and closing so I think your right, thanks
Post #359274 Wed Oct 10 2012 10:05pm
mjbrr
Yes mine squeaks.
It's the EGR valves cycling to prevent sticking. 2009 3.6 TDV8 HSE Santorini Black
Post #359275 Wed Oct 10 2012 10:28pm
TST717
Scotland
I had a similar 'run on after ignition off ' in a Merc recently ..... faulty Fuel pump diagnosed ........ replaced - Fixed .....
Post #359431 Thu Oct 11 2012 10:34pm
