![]() | Home > Wheels & Tyres > FRONT 285/35/21 REAR 325/30/21 IS IT POSSIBLE??? |
Why would you want to do this |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
you do need help mate ![]() ![]() |
kml4ever Member Since: 23 Dec 2011 Location: İstanbul Posts: 35 ![]() ![]() ![]() |
İ have 22 inches with 285/35 tires and those are big for the car on the other the 21 inches that i want is stays in my garage and i like the look when rears are wider |
İs it ok now? KML4EVER |
I think your gear changes will get quite erratic of you start swapping profile sizes front and back. RRS gone
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
One easy way to find out ask Project Kahn
I ve check out kahn their rear wheels concave but tire sizes are the same for fromt and rear so i dont know what to do |
gottcha, now that you have edited your header, this makes sense, i thought you where asking about putting 22" on the rear, and 21" on the front, but what your really asking is the WIDTH of the wheel.
What i mean is i want to put 21 s front and rear but rear wheels will be wider so while front tires are 275 rears are 315. 22 s are what i have now KML4EVER |
saimans Member Since: 22 Oct 2012 Location: UK Posts: 46 ![]() ![]() |
Cant say I have every come across staggered tyre sizes on the Range Rovers. Not sure why this is as the like of BMW X5s do have wider rear wheels and tyres |
Dingoz Member Since: 27 Sep 2012 Location: Tootgarook Posts: 16 ![]() ![]() ![]() |
Biggest worry would be the rolling circumference/tire diameter. If they are too different from each other, it might introduce tyre slip on wet roads and make the car a bit skatey. If the diameters are very close to each other the width wouldn't matter much. But you need to look at how far each size tyre travels with one revolution, ic the circumference RRS '05 4.4 Bonatti Gray Black Leather
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
I think LR would have a specification for the speed difference front to rear, if thats with in tolerance it would be fine RRS '05 4.4 Bonatti Gray Black Leather
