![]() | Home > Technical > Suspension & Sat Nav Problem |
Brian GOG Member Since: 01 Aug 2012 Location: Leeds Posts: 14 ![]() ![]() |
The shuddering is more likely to be the torque convertor vibrating under load. We see alot of these on D3 and RRS. Usually on vehicles with 100k plus but I have seen it on some as low as 40k. Are you local to Leeds so I could road test it with you?
m3grant Member Since: 05 Dec 2011 Location: Carlisle Posts: 18 ![]() ![]() ![]() |
Hi Brian, thanks for your reply.
Experience mainly! The way I had it described to me was the fins inside the convertor that push the oil round to build up pressure wear away and the thinner they get means they distort when under load. This causes the vibration as they flex. The guy I would recommend for the repair is Martin Lowe of Barnsley 01226 283196 ( He has his own recovery truck ). Once you have had it confirmed or denied I would get it touch with them and he can talk to you in more detail. Tell him that Brian from Green Oval has given you his number. Really nice honest guy, I use him for all the time.
Thanks for the info Brian. It's going into the workshop next Saturday so I'll get them to check it out. I've had a look on the web and the TC is an expensive piece of kit. If it needs one I'll give the bloke you recommended a call to see what he says. Fingers crossed its something cheap |
When he did mine on my D3 he fitted a telfon (like) coated torque convertor. Drives sweet as a nut now. They do a quality job but I won't comment on prices as it's not my business!
It is possible to do a DIY test on a torque convertor.
