![]() | Home > Maintenance & Modifications > EPB won't release, LPR say collapsed brake shoe, warranty? |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Not on site today (day off) but have PM'd! |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Nice try |
Its a fine line - i have had previous brake systems replaced under warranty - just to say they are a consumable item doesn't absolve them from faults Mike
Agreed Ive had faulty calipers etc replaced but running a consumable part till is disntegrates itsnt the manufacturers fault ![]() Out of interest fkarim do you have the LR MOT insurance? |
No - but to blanketly say its a consumable part is the consumers fault either If you had a brake pad with 50% life in it, and the calliper fails and destroys the remaining 50% i would expect that to be covered by warranty. Ive had ball joints and similar also replaced under warranty in the past. Its as much about how it failed and how old rather than the part. Mike 2014 Facelift Discovery |
I didnt say that did I
I may wrongly be assuming the shoes have never been looked at but on a 3yr old RRS they are gonna be needing to be done. Always worth a try getting LR to foot the bill but in this occassion is sounds very much like a dead end IMO. |
I didnt say you said that |
Yes, the LR Approved warranty I've got includes MOT insurance which does cover these parts. However, the car wasn't being MOT tested this time. After last 2 visits (service and MOT test 3-4 months ago and compressor replacement under warranty 2 months ago) the advice given on both occasions was only about replacing brake pads which I followed. Don't think I've done that many miles since these visits. Latest update from the dealership is that the cause is excessive build up of muck and grime which accelerated the wear on the shoes, leading to break up. Probably a punishment for taking it offroad a week before this happened. Although I did get it washed properly underneath, wheels & arches, discs and everything afterwards and would have thought a capable 4x4 would survive a bit of non-extreme fun. There I was thinking I haven't done any damage apart from scratching the wheels a little bit ![]() Think the best resolution I can now hope for is a forum discount on parts & labour ... waiting for David to return from his meeting and look at what he can offer. |
All cars, that use brakes as part of the off road capability systems (eg Terrain response etc), hammer the brake pads - the mud is abrasive - makes it like sandpaper on the disks and the systems and you use the brakes a lot.
Only offroaded once for 2-3 hours total. By the way it's not the discs or pads that failed, it's the shoes. |
You could have a chat with the guys who did the disks and pads but suspect they will just claim you didnt ask them to check. Hopefully LPR with sort you out mate ![]() |
They only changed the pads. Have already spoken to them and they say they don't check/adjust anything else when changing just the pads. |
LPR offered a discount, work carried out and car returned last night. All looks good. Thanks Wayne, David and James |
Only had select and genuine factory warranty - glad you got it sorted Mike
