![]() | Home > Australia & New Zealand > New Key. |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
It may be worth contacting a certain gentleman on the D3 site, i believe he is the parts manager for Yeovil LR and gives good deals for the antipodean region, that said you may have to end up getting the thing programmed by the dealer or at least a specialist after. I just had the batteries changed on mine, $23 dollars for both fitted, is the key kaputt ![]() MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
petsar68 Member Since: 24 Aug 2012 Location: Arrowtown - Otago Posts: 8 ![]() ![]() ![]() |
Zilch - thanks for your reply. One of the keys outcasings needs to be replaced and we dont have a spare. I'll give LR Yeovil a call, its got to be cheaper than $661 !! RRS TDV6 HSE
If it's only the key case you need then try.
SRE - thats fantastic, many thanks. RRS TDV6 HSE
Update - all sorted and new key enroute from the UK all for $200, quite a saving ! RRS TDV6 HSE
Is it the correct frequency for NZ use?? If you buy a Uk freq key it will not work in Aust. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
The LR main dealer who i am buying it through knows it's a NZ car as i quoted the chasis number and sent them a copy of my registration doc so i can only hope it will work here.
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
it will work just fine, keys are cut and programmed to your vehicle from your VIN so it will be the correct frequency Sophie Alltoft
