Home > Maintenance & Modifications > decat pipe mod
vic_ster51
United Kingdom 2005 Range Rover Sport TDV6 HSE Luxury Java Black
decat pipe mod
Anyone ever fitted decat pipe to there sport... i have 2005 model was looking at this.... just wondered if easy straight swap over fit etc.... current system is fully standard
and is the below 1 any good
thanks guys
http://www.alivetuning.com/Disco-3-Range-R...-Pipe.html c ebb
Post #357454 Fri Sep 21 2012 5:11pm
m22 gtr
Scotland
Looks good I would like to try it
Post #357460 Fri Sep 21 2012 5:32pm
mlines
So how do you tell the engine management system that the cat has gone?
How well do they pass the emissions part of the MOT without a Cat? (Yes, I do know its possible for a vehicle to pass without a cat if the engine emissions are low enough without one) 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #357464 Fri Sep 21 2012 6:42pm
vic_ster51
shouldnt fault anything i dont think
and mot in england dont check emissons as such like that no more c ebb
Post #357470 Fri Sep 21 2012 7:21pm
Since spring of this year, if the vehicle has a cat fitted as standard (and they all do these days) and it is not present at the test then it's a straight fail.
http://www.motchecklist.co.uk/mot-2012-changes.html 2012 SDV6 - it's missing a couple of cylinders
Post #357489 Sat Sep 22 2012 6:22am
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
No its not. It only has to be present on a vehicle which is subject to a full CAT test. Currently this is PETROL CARS ONLY.
If you have a diesel, you DO NOT need a cat to pass an MOT, as they are only subject to a smoke test
To the OP, get it bought and fitted. Will release a few extra HP, will give you a big more low down torque, and the turbo spools up quicker. Definately a noticeable difference, and one of the cheaper mods available
Post #357595 Sun Sep 23 2012 7:41am
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
Dmike is correct, diesel only get a smoke test no emissions. If you took some fog and put it in a jar, would it be missed.
Post #357598 Sun Sep 23 2012 7:55am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Yes however exhaust systems are checked for 'completeness' regardless of engine type. Missing CATs are a fail therefore I presume.
This is from the Directgov. website regards MOTs:
"Exhaust system
Secure. Complete. Catalyst missing where one was fitted as standard. Without serious leaks and is not too noisy."
This is part of the visual inspection not emissions/ smoke test. As such I presume a missing CAT on a diesel motor will be a fail.
Regards
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #357603 Sun Sep 23 2012 8:30am
Disco_Mikey
I appear to have broken the links. Will update this evening. You DO NOT need a cat for an MOT...
Post #357704 Mon Sep 24 2012 11:50am
Disco_Mikey
Taken from here: http://www.306oc.co....hread-2831.html
This is the question, asked directly to VOSA...
Quote:
Hello there,
There seems to be very mixed opinions across the internet and forums
regarding the new 2012 rules for MOT testing. Now I am interested in the
'presence of a cat' rule.
The way I have understood it is that a catalytic converter MUST be present
on a vehicle which was factory fitted with one, but only if it requires an
emmisions test to pass the MOT. Now I know diesels DO NOT require an
emmisions test, just a smoke density test, so am I correct in thinking that
a diesel with a 'decat' (straight pipe in place of the original catalytic
converter) will pass the MOT like this, assuming the pipe is secure and not
leaking at all.
I ask becuase this is a very popular modification and myself and others
would be very grateful to know exactly whether this is reason for a refusal
or not.
Thank you for your time,
Tom
And this was the reply, directly from VOSA...
Quote:
Dear Mr S,
Thank you for your email enquiry dated 12th April 2012, concerning an MOT.
The check for a CAT only applies to petrol engined vehicles which qualify
for a full CAT test. There will be an update to the IM in Spring which will
clarify this.
The fitment of a catalytic converter to petrol engine vehicles is mandatory
for vehicles of the specified age and type e.g. passenger car, goods etc.
The MOT Inspection Manual can therefore specify exactly what petrol engine
vehicles must have a catalyst fitted.
I hope this information has assisted you with your enquiry, but if you have
any further questions please do not hesitate to contact us again.
Kind Regards
Rebecca
Customer Service Centre
VOSA Operations Directorate
And also, copied from the MOT testers manual...
Quote:
"New Rfr where a catalytic converters are not fitted to vehicles subject to a full cat test."
Its is only petrol cars that are subject to a full cat test, diesels are only a smoke test...
I hope this clear up any confusion Thumbs Up
Post #357761 Tue Sep 25 2012 5:15am
Guyzer73
MIke,
I found the same so stand corrected Thumbs Up But have to say it's very confusing... And on top of the MOT you have the C&U which aren't back to back...
From a similar site it seems that in theory it's now possible to pass an MOT but fail on C&U, or vice versa Confused So joe public who modifies their car is Censored
This is where I prefer the German TUV system, if you modify your car in certain areas you have to go to the TUV for approval and it is wrtten into the cars papers. I had a Defender when living in Germany and due to all the modifications I required a 2nd sheet to list changes, plus all valid tyre and wheel combos. Everytime the POlice stopped me I gave them the document they looked at it and didn't bother checking because all required modifications where listed and approved...
Post #357762 Tue Sep 25 2012 5:33am
Disco_Mikey
Yup, same as aftermarket HID kits...
You can pass an MOT with them, as they light up the right colour, and the beam pattern is correct, but you can be stopped by the police, as they are not approved for use in non-projector type headlamps...
As we are discussing the legalities of a decat for MOT purposes, it will be fine. And I can't imagine traffic police will be too worried about a decat, especially if its hidden behind a plastic undertray Thumbs Up
Post #357763 Tue Sep 25 2012 5:47am
