![]() | Home > Faults & Fixes > Adaptive Cruise Control issue - Help needed |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
ACC only works if cruise control is engaged. Some RRSs have forward alert too which is engaged via a button next to the lock/unlock buttons above the radio.
Mr Rox Member Since: 16 Sep 2012 Location: London Posts: 10 ![]() ![]() |
Thanks for getting back to me Mr Frog.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
ive got ACC on mine with forward alert, and ive never had that message, so im guessing yours will have a fault 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
I have ACC but not forward alert and if I increase or decrease the distance with cruise off, I get a message to the effect or something not being available, can't remember the exact message through ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
Just checked on my way home, cruise control off, press the distance button (top left of steering wheel) and the display said "Forward alert off", which makes sense since I don't have fwd alert, but have ACC for cruise. |
Thanks.
Just trying to understand... The radar sensor mounted in the front bumper is the difference between CC and ACC. How can you have ACC with no forward alert? In that case you just have cruise control. How do you have ACC then? ![]() Why do you test with the cruise control off? Even if you have forward alert its not going to show simply because you have cruise control off! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
I would suggest you read the manual, then try what your going to on a nice empty road, not wanting to sound harsh but your going to end up up the arse of a truck wondering why the car didn't stop, warn you or made you a brew........
Many thanks for suggesting to read the manual.I know exactly how ACC works, thank you! |
Ok, I can tell you clearly understand how it works. ![]() 1. Forward alert is independent of cc, if you haven't got it then don't worry about it.(although as far as I know it's part of the acc) 2. Acc can only work with cruise control, the hint is in the name..... If you took some fog and put it in a jar, would it be missed. |
Yes, nothing to worry.
Confused !!!
Bobby: ACC does not work with CC. It is a different set up altogether.
Wow, this really has turned into a right debate..
