Home > General > Car dead after 1 week holiday |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Sheesh....the worst "I've been on a few holidays recently' thread
Mon Sep 17 2012 9:02am |
chilly Member Since: 07 Dec 2010 Location: north east Posts: 192 |
i had this before mate it was my upper tailgate realse button corroded behind the rubber and was causing a permant live think that was about 80 quid to fix. alos do you have a fridge if your leaving that on when away this can affect things or so lr told me , but you might need a new battery now aswell as mine had been affected by it going dead all the time but since got tailgate done and new battery not had a problem and mine often gets left for a few weeks at a time only the dead truely know peace,
Mon Sep 17 2012 9:26am |
If you are in the AA/RAC then call them out, they will put their electronic machine on your battery terminals to see if there is a continuous drain on your battery, then i'm sure they will be able to detect where it is. If your not in any breakdown/recovery service, then may i suggest you join one. |
Mon Sep 17 2012 11:33am |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
dont think aa/rac are going to spend hours trying to detect a drain on your battery pulling fuses and shutting down each ecu check your upper tailgate switch this is normally the cause of a battery brain |
Mon Sep 17 2012 5:40pm |
The other thing - do you lower it to access mode when you go away? With pre-2010MY cars
Mon Sep 17 2012 6:45pm |
Oh yes they do, but it doesn't take them hours, they have some clever kit in their vans, otherwise they will have to keep coming out to you everytime your battery goes flat costing the company more money. They have to diagnose and try to fix the problem where possible. Otherwise they can't fill in their report in the actions taken to solve or repair the problem and it goes against the companies action policy |
Mon Sep 17 2012 7:50pm |
solve problem-battery dead, repair problem-jumpstart dont think they are going to check every system in the car if they have got you going just incase its a battery drain when it could just be a wornout battery i know this because i called the aa out twice for my battery drain, on both occasions they jumpstarted the car and checked output of battery when running and after systems had shut down both were fine because drain was so small it took a week to drain battery with the car not being used the aa/rac dont have that much time to fix a job |
Mon Sep 17 2012 8:47pm |
I beg to differ, but will leave it at that. |
Mon Sep 17 2012 9:08pm |
Cheney Jawa Member Since: 25 May 2012 Location: Birmingham Posts: 89 |
Picked my new one up yesterday & the dealer mentioned similar to me about if i was going to leave it a long time stood then lower the suspension because if you don't the battery will drain Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack |
Thu Sep 20 2012 12:36pm |
Sirwacko Member Since: 22 Mar 2012 Location: Near Blackpool Posts: 74 |
Cheers for all of your advice guys. It's booked in for tues! RRS Dynamic |
Thu Sep 20 2012 1:55pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1671 |
Just retuned to the car from 12 days away. Parked (at home fortunately) with the suspension lowered. Dead as a DoDo. Charged the battery for a while then started fine. Everything reset (clock, date, A/C, seats).
Thu Sep 27 2012 10:22pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Exactly my experience with the AA. |
Fri Sep 28 2012 6:08am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
it's in their interest to prove/suggest the battery is faulty so that they can flog you a new one there and then. The AA especially heavily incentivise their drivers to make sales like this. ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Mon Oct 01 2012 12:18pm |
Sirwacko - did you get this resolved ? what was the problem/fix ON THE WAY: BMW F21 M140i
Mon Oct 01 2012 12:41pm |
