![]() | Home > Maintenance & Modifications > DIY twin iPOD lead installation |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
I decided to go a bit DIY for fitting my iPod in my 2005MY RRS.
I've looked up the part number for the clips that tend to go wayward: FYC500040, CLIP, STEEL.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Is the volume still lower on the aux setting connecting this way,or has it rectified that?
Should be exactly the same, I've just tapped into the wires closer to the head unit, there are no electronics between the AUX jack and the head unit, just wiring so no reason for it to be any different. |
So have you not noticed a difference in volume when you switch between Aux and radio or cd? |
I haven't used the radio or CD since so can't answer I am afraid, but nothing I did would have improved or made it any worse. ![]() "Roads ? Where we're going there are no roads." Back to the future. |
The aux input volume is lower on mine,and others have mentioned this as well. |
Tried it this morning and aux is lower than the radio on mine too. I guess it's because people could plug all manner of things in the jack, particularly output from the headphones of their mp3 player which is higher level (more volts) than an AUX output from the iPod's dock connector or other "proper" auxiliary output. This in turn could lead to distortion when fed headphone outputs if they had set the input to "official" aux levels. Hope this makes sense. Took a few more pictures this morning iPod classic in glovebox
iJet remote receiver in dock connector
iJet Remote
iPhone on windscreen mount
"dummy" jack in aux socket behind armrest
Cheers,didn't think it would have sorted the volume issue.This was my iPod/iPhone solution.
Very sweet |
Ive not looked - certainly on older models - but cant you set a range of those preset volumes, like the mobile phone level etc.
Google doesn't come up with any tricks for changing the AUX volume. Someone on a different forum suggested turning Logic 7 off, but that made zero difference to mine. |
I wouldnt have search on google and the logic 7 thing, well i would say thats rubbish. Search on here Mike 2014 Facelift Discovery |
here you go...a proper search here and got it...im not saying its going to work for you: (BTW - look at the bottom for pre 2009 cars)
and Mike 2014 Facelift Discovery |
