Home > General > NEW FFRR with Factor 22's |
Every element will be evolved and improved as land rover always do...they won't make a car and go backwards hence better Design, capability, equipment, etc Mike 2014 Facelift Discovery |
Sun Sep 09 2012 4:15pm |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
Stick you sport in a muddy football field with new road tyres see what you look like then, up to you sills in crap and no way out, before the usual babble on about user error, I went through the right proceedure ( although if you need a training course and a manual then it's no bloody good anyway)
Sun Sep 09 2012 6:32pm |
Both my 20's standard have been fine in the fields...wet grass muddy...it's about the max I would personally take the sport in anyway, remember they are about 80/20 road bias but that doesn't hugely hamper them until they fall off the cliff just like the point at's fail and you need full muds.
Sun Sep 09 2012 7:19pm |
crookedm Member Since: 03 Apr 2012 Location: North West Posts: 296 |
What size should be on the RRS for optimum driving on muddy football pitches? Serious question would it be 19's? |
Sun Sep 09 2012 7:43pm |
It's not the size as much as the tyres and there are more 19's at's, MUDs and more off road biased tyres for 19 rims 20 inch rims can also pinch the tyre sidewall a little more on rocky terrain etc that 19's...but obviously that's all to do with sidewall profile Mike 2014 Facelift Discovery |
Sun Sep 09 2012 8:16pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
As mse said, 19inch wheels tend to be supplied with mud and snow tyres, whereas 20s are mainly road based patterns, saying that, I park a fair bit in fields when spectating at rallys and when the snow was bad 2 years ago, mine manages brilliantly on 20s, as long as you select the right setting and don't give it gas and spin the wheels u won't look like a t tt Cheers Dave MY10 TDV6 SE (debadged ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps! Gone: a comprehensive list of imprezas and a Merc ML AMG |
Sun Sep 09 2012 8:39pm |
Cheers guys always wondered. |
Sun Sep 09 2012 8:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
If it looks like the concept vehicle and has the same sort of electronics and clever systems / suspension as the D4/RRS/FFRR then it won't be better as a farm vehicle. The Defender needs to be tough, reliable, easy/cheap to fix, have an interior that can take having sheep/sheep thrown at it etc. Having toys and a nice design and sparkly interior is not what the Defender needs. If they just round the corners, stick a modern efficient engine in and improve things like door sealing etc. then that will be an improvement. If they turn it into a £35k lifestyle choice then it'll sell well but won't be the Defender that traditional Defender/Series owners need. I hope they don't fall in to this trap but I fear they will. LR is losing touch with its roots. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Sep 09 2012 10:47pm |
Apart from the fact land rover have stated very clearly that the defender will have numerous washout interior models just as they are now. Current defenders have electronics as for recent years...infact the other makes that farmers buy (because the are cheap) have more electronics and are often more expensive to repair if they break out of warrant...but equally have all the toys anyway...actually the numbers of farmers with mitsushitties or disco 3/4 is increasing...so I don't honk technology is the issue or a problem or a bad thing I would agree most want it to be cheap...but that isn't wholesale the case now. Where the others score and defender doesn't is the none farmer/and us market where toys are needed and the new concept meets that. Incidentally...most tractors make our range rovers look like they are from the dark ages!!!! Serious technology on board and have for years, not just cleaver suspension, but self drive, navigation, measuring, control systems, infotainment you name it. The world moves on! Mike 2014 Facelift Discovery |
Sun Sep 09 2012 11:13pm |
Grahamsjz Member Since: 27 Feb 2012 Location: London Posts: 68 |
Is it the angle of the photo or is there a huge rear overhang? Given the short front overhang it looks as if the body has been plonked on its wheels a bit too far back.
Mon Sep 10 2012 6:06am |
i can see both your points, but the one thing a defender needs is to be worked on "in the field", landrovers are supposed to be modular and sorted by someone with a bit of mechanical knowlage, loads of electronics are no use when you are broken down in the middle of the khalahari! maybe the next generation will be able to download fixes from satalite cheers dave MY10 TDV6 SE (debadged ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps! Gone: a comprehensive list of imprezas and a Merc ML AMG |
Mon Sep 10 2012 8:19am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
wait a minute.. if memory serves.. didn't you forget to disengage DSC, and that was why you got stuck? as for the need-to-learn-how-do-something making that something no bloody good.. well.. there we go. ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Mon Sep 10 2012 11:21am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
OT - rrsboy, so if faced with a situation of a wet field, I would select the appropriate mode'grass, gravel & snow' then disengage the DSC, correct ? ON THE WAY: BMW F21 M140i
Mon Sep 10 2012 11:26am |
you might get away with the normal terrain setting, depending on how wet it was (the setting damps the throttle mainly)
Mon Sep 10 2012 11:28am |
