Home > Maintenance & Modifications > Brembo Disks
Bobby_1959
Brembo Disks
I have been told by my local garage that I need to change my disks front and rear
Is there a way I can check them myself?
What do I look for?
Post #356059 Sun Sep 09 2012 2:47pm
Bodsy
Site Sponsor
This will tell you how to do most things,
http://www.disco3.co.uk/gallery/albums/use...ssPics.pdf Thumbs Up
but I have not updated it to include front brembos. If you take some photos when you do them, I'd be happy to update it. Thumbs Up
Your rears will be as per the bible, but your front calipers are different. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #356065 Sun Sep 09 2012 3:38pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
Easy jobby to do and cheap enough, but simply ask them why, it can be obvious from visually inspecting them if they are worn, you will see grooves or usually you can see the original size around the edge if that makes sence. If you took some fog and put it in a jar, would it be missed.
Post #356076 Sun Sep 09 2012 6:34pm
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
You didn't mention year of your car and miles. My 09 has 29k miles on it and I had new front discs and pads installed 5 months ago. The fronts wear faster than the rears. Today I had my rear discs resurfaced and new pads and sensor installed at $266 US.
They have to use a micrometer to be able to tell if there is enough disc left to resurface. I found that Range Rover dealers like to change the discs when the pads are changed , but it is not always necessary. Mike mike murphy
Post #356186 Tue Sep 11 2012 1:09am
Bobby_1959
Is there a disk thickness or amount of wear which indicates when to change/
Post #357089 Wed Sep 19 2012 6:29am
Bodsy
Site Sponsor
Onthe normal and petrol d3 v8 disks, it is 20mm for new and 17mm replacement needed on the rears and 30mm for new and 27mm replacement needed on the fronts. Thumbs Up Bodsys Brake Bible
See it HERE
Post #357091 Wed Sep 19 2012 7:00am
