Home > Technical > Washer jet problem
anothermoneypit
Washer jet problem
More annoying than you would think... but my drivers side nozle has stopped working, water tank full and the LH side is working fine...
Removed the sound deadning but nothing too obvious as the tubes are as expected...
Anyone else experienced this - annoying and cant find the time to get her to the garage just now for a once over Big Cry
Post #354432 Wed Aug 22 2012 2:16pm
Paddi
Sorted same problem by pulling out a single bristle from a yard broom and poking it down the washer jets as far as possible. Not as risky as using a needle (as the LR manual helpfully suggests) since the bristle can't damage anything - just make sure you keep hold of the end.
As you might have noted from a previous post I have bigger probs with my RRS right now Big Cry ! 2008 MY Java Black TDV8 HSE
Post #354437 Wed Aug 22 2012 2:58pm
Skipper
Similar advice here, but I used a piece of wire from a wire brush. Worked a treat Thumbs Up
Post #354438 Wed Aug 22 2012 3:07pm
