![]() | Home > Technical > Intermittent warning messages |
Welcome. Haven't had these issues on my recently acquired 2007 TDV8 (I'm a newcomer too) but have been avidly reading the posts on this great resource and noted that apparently random messages can be associated with a poor battery. If the battery can't deliver a voltage close to normal then some electronics just don't work properly. I first experienced this many years ago after converting my Mk 1 Escort Mexico to contactless ignition; it was possible for the battery to turn over the engine but without at least 12.0 volts the ignition system didn't produce a spark. Have you put a voltmeter on the battery after the car has stood unused overnight? A good battery will show up to about 13 volts and a poor one 9 volts or even less. According to an engineer friend this is the best way to assess a battery's health. If your car was left standing until the battery was totally drained it is unlikely that the battery will ever be restored to full health by charging. If you shop around a good battery can be had for less than a LR dealer will charge but make sure it has exactly the recommended specifications. 2008 MY Java Black TDV8 HSE
datman Member Since: 03 Aug 2012 Location: Aberdeen Posts: 3 ![]() ![]() ![]() |
Paddi,
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 ![]() |
slightly off topic sounds like a superb buy, just might be worth visiting a dealer to ensure all recalls have been done & its on latest software etc |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
I'd bet on the battery or alternator.
moparmuff Member Since: 25 May 2012 Location: S. Bucks Posts: 96 ![]() ![]() ![]() |
Low coolant level warning is a common fault , it needs the water bottle and sensor to be replaced as the floats are hopeless and deteriorate very quickly giving the false "Low coolant level" warning
Thanks to everyone for the suggestions. It does look like the battery and possibly the coolant sensor/bottle need to be investigated. I am curious about the "water in fuel" warning which isn't even in the handbook list of possible messages. I think, on balance, I'll take it to an independent LR specialist and have it plugged in to the diagnostic kit. Will report back on the findings. |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
"Water in fuel" could well be that the water sensor in the fuel filter has triggered.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
There is indeed a electronic water sensor on the fuel filter. If this has corroded, then it will give a false reading, triggering the low power mode, drain the filter, or better still, take it to an indie, and get them to do a full service on it, that way they will change the filter anyway, and oil, and give it an inspection. I did that with mine when i first bought it, regardless of it having a full service history 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Its also possible that as it was not being used for "some months" that water has settle out of the fuel in the tank and has been sucked through to the fuel filter.
