![]() | Home > General > RRS Lowered Suspension |
T8OOL Member Since: 16 Sep 2011 Location: Essex Posts: 242 ![]() ![]() ![]() |
Had my car in for an MOT today and LR tells me mine has aftermarket lowered suspension (I thought it sat lower than others).
anothermoneypit Member Since: 27 Apr 2012 Location: Edinburgh Posts: 91 ![]() ![]() ![]() |
I lowered my vouge with the aftermarket link arms avaialble on eBay circa �100 - I'm considering having the ECU adjust the ride by 15-20mm on my RRS now but everyone I've spoken to has told me avoid.. running 22's with the lowered ride may make it unbearable (dependant on the roads clearly)
Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
If the ride is ok, I would leave it as it is! LCFC. Receiver of threatening letters from Overfinch. |
x2 - if its done and looks good and you can handle the ride - no point changing |
decided to keep as is, it looks better than standard and the ride is ok, never noticed a difference although I've since found out it could be a bit softer, seems ok with me.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
If LR know it's lowered then they'll definitely chuck out any suspension warranty claims. If it's just the dealer then you might be able to sweet talk them in to ignoring the lower stance if it does require a warranty claim. Depends how well you get on with the service guys I guess.
