Home > Maintenance & Modifications > door trim on bottom of front doors
mark hamster
when closing my drivers door today i noticed that the bit of trim on the outside at the bottom of the door has come loose.how do you tighten it up.? any idea's plz Rolling Eyes Rolling Eyes
Post #352526 Tue Jul 31 2012 11:41pm
It's held on by clips so you will need to replace the clip to sort it out. I had mine done by the garage last time mine was loose - as it was done during some other warranty work they didn't charge me.
No idea how to do it DIY, sorry. 2012 SDV6 - it's missing a couple of cylinders
Post #352538 Wed Aug 01 2012 7:01am
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Sometimes a good wallop sorts this. It might be a clip has come loose / broken or a strut has broken.
The front just pull off. Takes a bit of force and that will allow you to look. If possible you can stick your hand in the gap to check that the strut isn't damaged and that you have both bits of the popper at that location. If all OK then give it a good push (I kick mine)
Try this thread, or search +yellow +clip +popper for more details Smile
http://www.rrsport.co.uk/forum/topic26951....=door+trim 2011 Autobiography Santorini Black
Post #352545 Wed Aug 01 2012 9:39am
