Home > General > "Engine System Fault" |
mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111 |
Thanks RRS I think I will cry myself to sleep tonight and go put a deposit on a newer one tomorrow to cheer me up....... 2009 3.6 TDV8 HST |
Mon Jul 30 2012 6:55pm |
Ok, Just had a call off the "SPECIALIST" who said that the have concluded that there is a Turbo issue with the RRS. They have said that they want to put some Seafoam through the system to see if that rectifies my problem.
Tue Jul 31 2012 4:07pm |
The silence is deafening!!!!!!! I take it no one has any Seafoam esperience???? 2009 3.6 TDV8 HST |
Tue Jul 31 2012 6:07pm |
Nope, sorry Personally, i would just book it in at a trusted dealer and ask them to ring me when they have found the fault instead of everyone guessing. |
Tue Jul 31 2012 6:15pm |
I think he is reluctant to send to a main dealer due to high rates so I think I may have to just get my cash back!! 2009 3.6 TDV8 HST |
Tue Jul 31 2012 7:20pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Ive Seafoamed the oil, fuel system and engine and I can definitely say it is worth it. The benefits are; more power in the low range or better said, restored power. The fuel efficiency also improved. Not by much but it was noticeable. Lastly there is the satisfaction of knowing that there is less Carbon buildup in the system. I can't vouch for any other engine than the 5.0 supercharged petrol.
Mon May 23 2016 2:08am |
Seafoam sounds great, but all the crap it flushes from the engine has to pass the lambada sensors and also through the cats... |
Mon May 23 2016 8:51am |
So they go through the cats. I don't know how they work but I have NEVER had a catalytic converter clog or go bad. Has anyone? I've read this argument before and yes it makes sense but how big are these particles and does a catalytic converter filter it or just let it go through? Can anyone accurately answer that?... WAIT, I'll Google it lol |
Mon May 23 2016 4:20pm |
Ok I just googled it and basically the way a catalytic converter works is by heating up the elements inside so much that it burns off EVERYTHING and what comes out is just water, carbon dioxide and Nitrogen. Yes it looks like a filter but I will bet that any small chunks of carbon will just get burnt off and dissipate as a gas. The temps in there are in excess of 700 degrees Celsius (From what I saw/read) so that should be enough to change things around as it is intended to do.
Mon May 23 2016 5:13pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
Seafoaming is 'Italian tuneup' for people who do not have any opportunity to drive their car floored for 2 hours straight. Yes, it may remove some carbon buildup. In an engine that holds the oil inside the block because it is sealed with these deposits this will lead to excess oil usage and, eventually, to a catastrophical failure.
Mon May 23 2016 7:53pm |
I've not looked at how seafoam works, but I'll take your word that it raises engine temps etc. Surely though this's is worse than leaving any carbon deposits in situe ? I mean if the temps are that high they could make the carbon burn and pit the surface it is adheared to, not only that but as these lumps fall off they've got to go some where, so could end up trapped in piston rings and scour your liners. A well timed piece could get trapped between the valve and head, stick and then prevent the valve from closing properly until it is cleaned and rebedded.. the list goes on. I'll stick with a can of BG44 every couple of months or so. |
Mon May 23 2016 10:22pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
He's referring to catalytic converters when he mentions high temps and burning stuff.
Tue May 24 2016 7:31am |
I agree a lot of the stuff IS snake oil but let me rebut by showing you this video.
Tue May 24 2016 2:03pm |
Socast, I just edited my post to reflect that it does NOT raise the temps of your engine. I'm talking about the temps INSIDE the catalytic converter. Those temps can exceed 700 degrees Celcius. |
Tue May 24 2016 2:06pm |
