![]() | Home > Technical > SC engine cutout - mangment indicates no fuel pressure |
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 ![]() ![]() ![]() |
If it starts and then cuts out I'd put my money on needing a new battery...had the same issue with my wife's 2005 s/c all better now |
b3nle Member Since: 24 Jul 2012 Location: nr bridgend Posts: 10 ![]() ![]() ![]() |
battery is new and fuses ok...
Bobby might be the man off here that can help you out, he tends to hover around during the night. |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
try changing fuel filter sometimes causes fault to ping up saying low fuel pressure |
Anders-01 Member Since: 25 Jul 2012 Location: London Posts: 13 ![]() ![]() ![]() |
Mine needed a software update this solved the issue of cutting out. |
hi all, posting to get my posts up to 5 so i can PM Bobby! Thanks for the heads up! |
and another one! |
Hi guys,
