Maxarn58
Hello Mitchmx.
In order to complete the car with satnav and phone, You will need some new
wiringlooms, and a bluetoothmodule. The satnav consists of a screen, and a dvd-unit
(where hardware and software for nav is). The phone needs a bluetooth module, and
the triggers on the steeringvweel, right side (green and red receiver pic)
The entertainment system communicates via a most-cable, and if You should get your hands
on all the parts needed, they must be enabled with either a Faultmate or similar.
The stereo must be a high-line unit, that has the outlets/inlets for it all
(6cd changer, and the amplifier also must be compatible)
So, it will not be an easy job to upgrade the car to HSE spec, it is possible though, but a lot of effort.
There is a guy on the Disco 3 forum, (disco3.co.uk) who has done it, search there, the member there is called "Wiggs"
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
