Home > Technical > Front Active Sway Bar Replacement |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9002 |
Mine is having the rear one done at the moment. The most obvious symptom was fluid leaking out of it and covering everything around it. I thought I had a fuel leak such was the amount spread around.
Thu Jul 19 2012 10:20pm |
Mine has had front bushes etc replaced at 12months old, and the rear anti-sway assembly at 3 years.
Fri Jul 20 2012 11:14am |
RRSTDV8DK Member Since: 26 Mar 2007 Location: cph Posts: 67 |
Hi RRSTDV8
Fri Jul 20 2012 3:26pm |
RaNgE_RoVeR Member Since: 19 Jul 2012 Location: USA Posts: 2 |
Thanks for all the helpful info. The Land Rover technicians have officially diagnosed the noise as a faulty active sway bar. It's too bad the units aren't serviceable, as they are rather pricey to replace.
Fri Jul 20 2012 3:45pm |
