Home > eBay & Bargain Spots > Cheapest genuine range rover sport mud flaps I've found
Jonny Fresh
Beancounter_74 wrote:
Southern Jock wrote:
I did it and found it very straight forward. There's absolutely nothing to go wrong.
Undo a couple of screws and remove the trim. Re-use the same original screws and a couple of new ones and fit the mud flaps onto the same holes as before. You need to screw into a new hole but it's already marked up for you underneath the trim.
Hope it helps Thumbs Up
Many thanks Southern Jock Thumbs Up
Sounds like even I could manage that Laughing
I'm exactly the same......as soon as I read "undo a couple of screws..." that made it a job for the dealer Laughing
Post #321112 Mon Nov 14 2011 1:34pm
T8OOL
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Fitted mine today, pretty straight forward, but you need a stubby cross head screw driver. Also be aware when doing the fronts you get a couple of clips to use with the self tapper screws and they break really easily. I broke two when screwing the self tappers into them, had to get LR to send some replacements. Anyone else have the same issue? RR Sport TDV8 09 Santorini Black with all the trimmings
Post #321620 Thu Nov 17 2011 10:04pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Pics.would be good,mine arrived yesterday but I am a little unsure on fitting them now.It surprised me how high they come up the wheel arch and I'm unsure of the look and if they will damage the paintwork.
Post #321626 Thu Nov 17 2011 11:09pm
T8OOL
I'll post a couple of pics over the weekend. They are straightforward to fit, you just have to be carefull with the clips I referred to before.
Regarding the look, I think they look good and make the car look a little lower and wider at the rear.
You can fit them and then remove if not happy RR Sport TDV8 09 Santorini Black with all the trimmings
Post #321655 Fri Nov 18 2011 10:04am
cliftonvilla
Just a brain fart but,
Is it possible to fit mud flaps to RRS HSE Overfinch 2010MY Overfinch
Post #350710 Sun Jul 15 2012 7:38am
#76
Has anyone any new deals on a full set anywhere?....
Cheers. TDV8
Custom map & K&N
Straight through Exhaust
...Awesome!.
Post #363713 Mon Nov 19 2012 6:38pm
