![]() | Home > Wheels & Tyres > Wheel Centre Cap - Change |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
Take the wheel off and push it out from the inside using something like a socket extension bar. 2012 SDV6 - it's missing a couple of cylinders
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 ![]() ![]() ![]() |
Just done this and used a thin bladed scew driver..popped out easily and not a mark on the alloys..took about 1min per wheel |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Because I didnt want the old ones,I just shoved the screw driver through the centre and twisted it out. |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Roll gaffer tape back on itself and use the tack to pull them out... |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Leave car in carpark for a few hours then return to find that the
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
...or the rubber suction pad from a cup hook or similar works well... Carl |
RRSMK Member Since: 11 Jul 2012 Location: Milton Keynes Posts: 4 ![]() ![]() ![]() |
Thanks for all the tips, i will try them one by one and let you know which was successful. |
AAAAAAAAAAAAAAAAAAAAggggggggggggggggggggggggghhhhhhhhhhhhhhhhh ![]() ![]() ![]() ![]() They've done it again!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Probably on fleabay now |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
Where's it happening Endjin - I will avoid it!! |
Not 100% sure yet, You know what like, after replacing I remember for a wee while to check every time i go to my car but you soon forget and then boom another one vanishes! but, you then question if you just hadn't noticed and it's actually been gone a few days |
