![]() | Home > Wheels & Tyres > Tyre Rotation?? |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Maybe one of the resident tyre experts could help me with this one.
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
I was in exactly the same position and LR Leeds have just this week swapped mine over front to back, same side. They couldn't swap side to side as the tyres are rotational.
Bradders,
Im on Hankooks. When i questionned him about swapping as I'd heard that LR arent happy about it either, the Service Manager just laughed. FF 4.4 V8 Soooo looking forward to this bad boy
I understand that the concern is with handling, apparently it takes a few miles for the tyres to bed in. |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
i used to swap back to front on my Toyota Supra all the time as i was getting 3000 miles from a set of rears |
just got a digital thingy for checking tyre depth, based on the fact there is very little grip in the wet and that they look worn, i would have expected them to be less than the minimum, they are in fact between 3.75/4.2mm on front, rears are 6mm! so yes , i will be changing front to back this afternoon. the 4 brand new ones here are 7.75/7.8mm if anyone is interested!!
champmac Member Since: 28 Sep 2012 Location: hhffdhhh Posts: 1 ![]() |
Tyre wear varies depending on where it is fitted.Should your tyre suddenly deflate it is easier for the driver to maintain control of the vehicle if this happens at the front and not the back. used car dealer |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
The only issue you may have is when the tyres were fitted, the rears may not have been balanced, so when they are on the front, you might get a vibration through the steering.
