Home > Technical > Suspension Leak
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
Suspension Leak
lo all,
My car has been in today to check my Suspension Fault with amber light on.
They have found a leak where the two pipes go into the reservoir next to the compressor, they have said the compressor is working fine.
They have advised that the reservoir and two pipes need replacing.
Has anyone had this problem and was it resolved by replacing these parts?
Thanks
James
Post #349705 Tue Jul 03 2012 5:00pm
rstebbings
Did it look like this
This was fixed with an hours labour and a new pipe to the compressor
Post #349707 Tue Jul 03 2012 5:09pm
chapman_i.t
No it hasnt dropped at all.
But they have sprayed some soapy water on the pipes coming out of the reservoir and they are foaming a lot, definately a leak but they said to change both pipes and a new reservoir.
I just keep getting the light on the dash until the leak has been fixed.
James
Post #349715 Tue Jul 03 2012 7:35pm
chapman_i.t
Finally got my suspension light sorted..
Had a new air reservoir \ dryer fitted to the compressor which seems to have sorted the problem, light doesn't come on anymore.
Post #350950 Tue Jul 17 2012 6:34pm
rstebbings
Post #350951 Tue Jul 17 2012 6:39pm
