![]() | Home > General > car wont start |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
changed my fuel filter on my tdv8 today and now the pig wont start, anyone got any ideas please |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
A complete guess but does it only flow one way, and has it been checked to ensure it is the right way ?
you can only fit the filter one way as far as i can see mate |
Just a thought. MY16 AUTOBIOGRAPHY Indus silver with some toys
i belive you turn the ignition on and off about 5 times to prime system to which i have done and it wont star so wondered if there was a bleed nipple some where |
Do you have breakdown recovery |
yes i do mate but the car is in the garage now lol |
As in, repair garage or your garage ? |
its in my garage mate as its where i work, i have changed dozens off filters before but this one has bossed me and just looking for tips |
yes mate lol , i found it changed it and now it wont start |
Did the guide I posted help? Malaysia Boleh!
yes mate it did thanks, its a bit hard to find and a bit tricky to remove and to replace but a straight farward job for a compitant mechanic , i just carn understand why it wont start unless its because the battery wasnt turning the engine fast enough, on older stuff cracking the injectors open used to do the trick |
I would hope that you took care of the water-in-fuel sensor electrical connector and that the fuel filter element is properly aligned.
thanks mate , i have been searching on how to bleed the system al night and not found out yet lol some things are simple to find and other things are a nightmare to find |
