Home > Technical > power steering seems stiff and heavy
highfellzippy
any ideas on this ?? Thumbs Up
Post #349359 Sun Jul 01 2012 3:53pm
Have you checked the PAS reservoir in the engine bay? Make sure there is sufficient in there for a start... 2012 SDV6 - it's missing a couple of cylinders
Post #349379 Sun Jul 01 2012 7:16pm
Rover T
Ireland 2008 Range Rover Sport TDV6 HSE Stornoway Grey
When I start the car on the drive ,the steering seems heavy,then when I rev the engine to move ,the steering gets lighter with a small shudder. I wonder is it something to do with oil pressure/flow to the rack or from the power steering pump?
Post #359917 Wed Oct 17 2012 12:50am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Rover T - I'd suspect that the pump would be to blame for either of your suggestions.
Zippy - A number of things could be causing this - loose drive belt/faulty tensioner, faulty pump, sticky track tie rod ends, faulty steering rack or possibly the universal joint. I know a few people have had trouble with the UJ. Thinking outside the box - have you checked your tyre pressures lately?
Does the steering get lighter when you drive it or rev the engine? Do you hear any sounds from the engine bay when you turn the wheel?
Post #359981 Thu Oct 18 2012 12:32am
Culbert1
pump is going out, same issue happened to me
rebuild kit or a used pump run about the same cash, i went with a used pump from the salvage yard, selected it up for about 30 dollars, with less than 50k on it
Post #360607 Tue Oct 23 2012 3:49pm
