Home > Technical > Bouncing and hopping
Nice But Dim
Hi all,
On occasions while driving i get a bouncing, closest i can explain is that it feels as though i have warped wheel/tyre but as this only occurs occasionally i am dismising that possibility.
Can anyone offer a possible reason for the above, ring any bells with someone who has had similar? suspension maybe?
Thanks in advance.
Phil --------------------------
RRS S/C, Java Black
X-Type Jag sport
LR D2 GONE
BMW 540 GONE
Post #348513 Mon Jun 25 2012 6:33pm
JUCOTT01
Do you use access height mode??
And is it only at the beginning of the journey?
Check before you set off that you are in normal height
Thumbs Up RRS MY11 BALI BLUE OVERFINCH
Post #348841 Wed Jun 27 2012 7:32pm
Nice But Dim
Thanks for the reply.
The "bounce" can occur anytime, there seems to be no pattern to it, the car is not in access mode when its bouncing, i thought about flat spots on the tyres that have been a recent topic on here but i could say drive 30 miles, stop for fuel then drive off with the bounce occurring again, so it can't be flat spots on the tyres.
The car is due a service soon so i shall get the dealer to investigate it i suppose, i just posted as it may have jogged someone's memory who experienced something similar.
RRS S/C, Java Black
X-Type Jag sport
LR D2 GONE
BMW 540 GONE
Post #349126 Fri Jun 29 2012 8:15am
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
I had this on mine. Sent it in for four wheel alignment... Cured it Thumbs Up
Post #350365 Tue Jul 10 2012 10:09pm
Nice But Dim
Cured it
Had new tyres fitted today and while changing them the fitter found a inch long crack on the rim of the alloy, so alloy discarded and spare fitted while i source a new alloy, drove car and no more bouncing and hopping.
Also cured the pulling to the left i had never been able to get sorted even with a 4 wheel alignment, seems the old tyres were to blame for that to.
FYI Event mobile tyres fitted me new Hankooks £161 all in for each tyre, not bad i think and all done at my house.
RRS S/C, Java Black
X-Type Jag sport
LR D2 GONE
BMW 540 GONE
Post #351127 Thu Jul 19 2012 2:31pm
