Home > Off Roading & Green Laning > What 255/55/19 tyres for Morocco? |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 |
ATR Porsche Cayenne S Diesel 66 Plate |
Tue May 29 2012 4:51pm |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 |
Is that the Pirelli Scorpion ATR? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Tue May 29 2012 7:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The Scorpion ATR is 2 polyester plies in the sidewall, 6 in the tread (2 each of steel, nylon and polyester) 2012 SDV6 - it's missing a couple of cylinders
Tue May 29 2012 10:14pm |
Yes they are Pirelli, they are what most of the D3 guys use out there. Some have used AT2 but have had side wall problems. They are a great tyre and usable every day too. Porsche Cayenne S Diesel 66 Plate |
Wed May 30 2012 6:58am |
I have Scorpion ATRs fitted on my RRS and so far they have been very good on road. I'm taking them lightly off road in a couple of weeks at Eastnor so will see how they do then. 2012 SDV6 - it's missing a couple of cylinders
Wed May 30 2012 11:19pm |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 |
Depends on your budget
Thu May 31 2012 12:28pm |
Thanks Mike! Where did you get them from for £550? Cheapest I've found Grabbers is around £720 fitted! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE) - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
Mon Jun 11 2012 11:55am |
I have an ex-G4 challenge vehicle with 2 sets of wheels and currently both sets are fitted with 255/50/19 tyres. However, looking at the G4 spec sheets (http://www.g4ownersclub.com/Resources/2006/SpecSheets/SPECSHEET2006-RANGEROVERSPORT.PDF) they were fitted with 255/55/19 tyres.
Tue Jun 12 2012 11:43am |
I've found the fuel economy isn't quite so good with the 255/55. That might be because the larger diameter throws the distance travelled out and thus the calculated mileage. Not sure. It might just be because the deeper sidewall gives slightly more sidewall flex which obviously absorbs energy and thus uses more fuel. It might be a combination of the two. It's only 1-2mpg on a run and almost no different when just tooling around locally so it's not too much to worry about.
Tue Jun 12 2012 12:51pm |
Thanks RRSTDV8! I expected the 55 profile to raise the fuel economy if anything, as each revolution of the wheel would get you a bit further down the road! So was hoping for a very slight improvmenet on a run, if any change at all.
Tue Jun 12 2012 2:04pm |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 286 |
Worth a look at the Toyo Open Country. Please call us 01737 241370 for the quickest response
Wed Jun 20 2012 10:54am |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Think you will find the weight loading on the 55 profile is better than 50's, so if going loaded up and long way will give you a bigger margin of saftey.
Fri Jun 22 2012 7:58am |
