Home > General > Misfueling
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Misfueling
Having chuckled at other peoples misfortune in the past, I have gone and stuck some petrol in in the RRS!!
In 25 years driving I've never come close to doing it!!, I had just finished work and had a million things on my mind!
Anyway, the Misfueling device went off, but not after shoving half a ltr in, I decided to fill it up to the brim with diesel and see how things went. I have read a lot of conflicting reports on the net, from a couple of litres won't matter, to needing a full rebuild!! I have been driving gingerly and will probably keep topping it up every 50 miles, unless anyone else has some definitive advice!
Thanks
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #346307 Sat Jun 09 2012 10:26am
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Is the misfuelling device standard across the range?
My sister has a 59 plate HSE which was filled with unleaded and no device kicked in?
My wife filled her diesel golf with petrol at Tesco's last year, fortunately Tesco's offer a service where a company drains your tank on the forecourt for around £180.
Nik. 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #346323 Sat Jun 09 2012 12:16pm
Bodsy
Site Sponsor
1/2 a litre of petrol wont really make any difference to a full tank of diesel. You'll be fine. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #346326 Sat Jun 09 2012 12:27pm
codfather
Nik, if her 59 plate is an early facelifted one, then yes it should have it, but to be honest it feels more like that annoying way when the trigger splashes back all the time and cutting the flow, it doesn't actually divert the petrol won the overflow pipe!
Thanks bodsy,think I will stick a can of diesel flush through it as well, just to be safe!
Thanks
Post #346331 Sat Jun 09 2012 12:50pm
Mate of mine did exactly the same thing as you muddy, all was well for 257 miles later then B A N G Shocked Engine parts all over the M1 Rolling Eyes Not covered by warranty because they identified traces of petrol in fuel tank and filter..... Big Cry
Laughing Laughing Only kidding, Laughing i would ask advice from your dealer see what they recommend Thumbs Up Maybe change your fuel filter as a precaution.
Post #346347 Sat Jun 09 2012 4:43pm
I would not ask your dealer, they see the £££££ signs and throw your remaining warranty out the window
Half litre would not make much difference when mixed with a full tank, but I would check with a independent to make sure
I think someone was recommended to add 2stroke oil (correct spec 2so) and keep it brimmed to dilute the petrol over on freel2
Post #346349 Sat Jun 09 2012 4:51pm
0.5L in an 80L tank? Can't see any problem with that at all. I'd be amazed if even LR said it needed anything doing. 2012 SDV6 - it's missing a couple of cylinders
Post #346350 Sat Jun 09 2012 4:52pm
codfather
Since the first posts I have in fact spoken to the dealer, I was thinking they would want it in and change all of the ancillaries , but no, they said it will not be a problem, if I had half filled it that would be another story! He did back up what I thought of doing and put in an £18 can of diesel flush in it when it gets down to half full. funily enough I was talking to a lorry driver, who said he puts a bit of petrol in in extreme cold weather to stop it freezing
Cheers all
Post #346380 Sat Jun 09 2012 6:44pm
steverrs
Scotland 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Sorry to hear that this has happened. I have just paid for mine to be repaired after my wife put petrol in it and drove it until it stopped. In order to keep the warranty in place it cost me £4125 at the dealer (including a tank of fuel)
Having said that your not in the same position as you have put a very small amount in, however it may be worth asking (do you have a local independent in your area ?) as any future warranty claims will be rejected if any trace of petrol is found.
Post #346443 Sun Jun 10 2012 12:22pm
Camper
Isle Of Man 2008 Range Rover Sport TDV8 HSE Java Black
Oh my goodness
You let your wife drive it?
I got a horrible sickly feeling when I read that Very Happy Now - Black 2008 3.6 TDV8 RRS orgasmic
Gone - Black 2006 2.7 HSE RRS problems
Gone - Green 2008 SWB Defender fully loaded; brill
Gone - Green 2005 Disco diesel; brill
Gone - Black 2003 Disco diesel; brill
Post #346454 Sun Jun 10 2012 5:10pm
codfather
Blinking Heck!! Shocked £4 grand!! When I spoke to the service manager he laughed and said as long as it was only 60p it would be fine, I have actually kept topping it up with diesel each day to dilute it, not sure if it mixes or floats on top! Seems to be running smooth enough
Post #346490 Sun Jun 10 2012 9:14pm
