Home > General > Rust spots on wiper arms
Tonyrec
Both of our front wiper arms are showing signs of corrosion. It is worse on the drivers side around the rivet holding the two sections together and can be easily seen from the drivers seat.
It's not the end of the world but it does look quite bad and when you think that our car is not even 2 years old yet!
Has anyone else got this problem and approached LR about it ?
i could take the wipers off and respray them myself but the car is going in for its second service in 3 weeks so I think that i will mention it to them then.
Post #345848 Mon Jun 04 2012 5:49pm
scrumps
I had the same thing on mine (May 10 TDV8 HSE) but only the drivers side.
Supplying Main Stealer replaced it under warranty when the car went in for a few "niggles" to be sorted.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #345876 Tue Jun 05 2012 7:35am
Tonyrec
Scrumps, many thanks for the reply.
It does sound similar to ours so will see what the dealer says when it goes in for it's service.
Post #345879 Tue Jun 05 2012 8:32am
Supacat
Noticed the same things on mine so pleasantly surprised they were swapped out under warranty. Will have to discuss with my dealer to see if they will do the same.
Post #345888 Tue Jun 05 2012 11:37am
