Home > General > Tool kit quetion |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
If You read at page 247 in Your Owners Handbook,
Fri May 18 2012 2:02pm |
nobbyk Member Since: 18 May 2012 Location: United Kingdom Posts: 89 |
I thank you |
Mon May 21 2012 7:35am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
If turning the pages of the handbook is not your thing, then pop along to http://topix.landrover.jlrext.com/topix/vehicle/lookupForm In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon May 21 2012 8:36am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Reading the manual, whatever next!
Mon May 21 2012 9:32am |
MM, some do that..
Mon May 21 2012 8:46pm |
DaveRRS Member Since: 04 May 2012 Location: Reading, Berkshire Posts: 178 |
Page 247....
Mon May 21 2012 9:12pm |
Fairly sure they could have made the tool kit smaller tho, mine has the above by looks empty |
Mon May 21 2012 9:13pm |
I concur, just the jack and my removeable tow bar |
Tue May 22 2012 7:45am |
Yes but you can fit a lot more genuine stuff in there like:
Tue May 22 2012 8:58pm |
T8OOL Member Since: 16 Sep 2011 Location: Essex Posts: 242 |
Does anyone know the LR part number for the genuine, original RRS wheel brace? RR Sport TDV8 09 Santorini Black with all the trimmings |
Tue May 22 2012 9:19pm |
That would explain a lot, thanks MSE |
Thu May 24 2012 10:39am |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
The original jack and wheel brace are frankly rubbish. You will break the wheel brace very easily if your wheel nuts are on tight. I wouldn't rely on them. Have broken two without trying very hard. Replaced with proper tools now and 6 ton hydraulic bottle jack. Next items to go into this space will be dual battery set up (odesseys ) with Traxide dual battery controller. SWMBO owns this car I get to drive occasionally |
Thu May 24 2012 11:29am |
Whoosh . . . . . . . .!! Straight over |
Thu May 24 2012 11:35am |
