![]() | Home > General > Rear parking sensor On constantly when reversing |
marco247 Member Since: 25 Apr 2012 Location: Hull Posts: 57 ![]() ![]() ![]() |
Mine did the same and needed a new sensor |
Strathearn Engineering Member Since: 23 Mar 2012 Location: Aberuthven PH3 1HE Posts: 65 ![]() ![]() |
Could be either a faulty sensor, or wiring issue behind the bumper. |
Ticker Member Since: 05 Jan 2012 Location: Derbyshire Posts: 8 ![]() ![]() ![]() |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
Mine does the same one time per year.
AndyKay Member Since: 14 Jan 2012 Location: Leeds Posts: 226 ![]() ![]() ![]() |
mine does when it's been raining heavily RRS HSE TDV6 Autobiography |
Chris Sellers Member Since: 24 Sep 2011 Location: Midlands Posts: 14 ![]() ![]() |
Mine does the same after rain, I've always assumed it's just because it's wet. RR Sport SVR Santorini Black 16 (2017MY)
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 ![]() ![]() ![]() |
Mine did this once but was cured by a thorough clean of all the sensors. Was at the time of year when they were using loads of salt on the roads so put it down to a crusting of salt on the front of the sensors. Gordon Kerr
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 ![]() ![]() ![]() |
My 07 tdv8 used to do the same after very wash, think the stealerd changed very single sensor but still didn't fix the problem. Now have MY2012 and never had an issue 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
Daft question but do you have a tow bar fitted? When I bought my RRS I complained about same problem to the dealer. After investigation they found that the tow bar was interfering with the signal from the two inner sensors.
