Home > Technical > Hill Descent type suspension problem
SpikeUK
RRS 2006, 2.7 HSE, 66000 miles.
When I go around a moderately sharp bend, for example the sort of bend you get when you leave a motorway slip road and there's often a large loop to get to the next road. If I do that loop at more that 40 mph, it feels as if the Hill Descent is switching itself on. The suspension suddenly feels very strange and stiff, and it feels as if the ABS is limiting my speed with that grinding noise the Hill Descent makes.
As soon as the road straightens out, the car instantly returns to normal and everything's fine again, except that my heart rate's gone to more than 100 and I'm gripping the wheel with white knuckles.
Does anyone know what could be causing this? Thanks.
Post #344072 Fri May 18 2012 9:31am
JC1
just sounds like the traction control working as it should to me Whistle Whistle
i would ease of the gas a little Thumbs Up MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far.
Post #344098 Fri May 18 2012 11:53am
ChrisP
"Does anyone know what could be causing this? Thanks."
Driving like a cnut Rolling with laughter MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #344099 Fri May 18 2012 11:59am
JC1
Laughing Laughing I was too polite Rolling with laughter Rolling with laughter MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Post #344103 Fri May 18 2012 12:12pm
SpikeUK
Ha ha, very funny.
There is definately something wrong with a car that won't go around a bend at 40 mph.
So maybe the traction control is cutting in prematurely. Could someone sensible suggest possible reasons why that should be? Thanks.
Post #344106 Fri May 18 2012 12:20pm
ChrisP
Spike,
Seriously this could be your traction control/ABS which is cutting in because there is something wrong which is putting your car into imbalance and applying the brake to one of your discs and/or cutting power.
It could be something as simple as low tyre pressure which is causing a wheel to spin faster on a tight bend. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #344107 Fri May 18 2012 12:28pm
mlines
I would suggest Ride Height sensor.
Martin 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #344133 Fri May 18 2012 4:16pm
Bodsy
Site Sponsor
Low tyre pressure
Wheel alignment
Wheel speed sensor
Ride height sensor
Bald tyres!
There you go.... Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #344136 Fri May 18 2012 5:33pm
Also worth checking that the centre diff isn't locking for some reason - it'll show on the 4x4 info screen if it is. This will make the car feel out of sorts if it happens mid bend. Might be linked to a traction control issue.
Just a thought. 2012 SDV6 - it's missing a couple of cylinders
Post #344143 Fri May 18 2012 6:18pm
SpikeUK
In case anyone is wondering what the problem turned out to be, the suspension air compressor was packing up.
Post #358446 Tue Oct 02 2012 9:17am
