Home > General > Keyless Thefts |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
Seen many of these in the last 4/6 weeks on PistonHeads, mainly BMW's in the London Area. LCFC. Receiver of threatening letters from Overfinch. |
Thu May 10 2012 10:39am |
Be intrested to know what L/R are doing to combat this |
Thu May 10 2012 11:26am |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
They are probably responding as they usually do by doing sweet FA! Jim |
Fri May 11 2012 2:39pm |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Heard a few stories about tucking your OBD port away and putting a fake one there......maybe wire to high voltage |
Fri May 11 2012 4:09pm |
To be honest this has been going on for years, it used to be rife with performance cars back in the early 2000, only what they did back then is see a particular vehicle they wanted (usually the cars they delt in or had a lot of knowledge of) take along a few needed parts ie set of keys, ecu and ignition barrel to fit the keys they take with them, and with a bit of knowhow your car was gone, never to be seen again Pointless having a tracker because these guys know exactly where they are fitted to the cars they are stealing, many trackers have been found in fields by the roadside. The things these guys get up to is unbelievable |
Fri May 11 2012 4:33pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Ady - Are you saying that trackers are generally installed in one location, my understanding was that they were not? |
Sat May 12 2012 7:47am |
No leeds, there are several locations where they are installed on a motor but the organised crooks who take these motors know where they are installed, its usually one of about 3 places on a vehicle and usually somewhere easy to access wiring. |
Sat May 12 2012 8:36am |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
Good old streering lock, never go this keyless stuff seeing you still have to have a fob/key, for the 5 seconds it takes to slot it in the hole why bother ! |
Sat May 12 2012 12:43pm |
Because its better and a key is even easier to replicate and steel Mike 2014 Facelift Discovery |
Sat May 12 2012 1:00pm |
