![]() | Home > Off Roading & Green Laning > Does a G4 need any additions to protect/improve it offroad? |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
No, not really. You may want to consider a 2nd battery setup and it should still have the UHF radio power lead & speaker in the top glovebox, so it's not difficult to add one of those if you want. Look for the Traxide kit if you want a 2nd battery, it's a plug & play setup designed for the D3/RRS. Also helps to extend the life of the main battery.
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Thanks Mike! Didn't realise they had UHF radio wiring, where is the antenna?
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
it contains the filter
I see! The car has done 60k miles, so a full service, full fluid and filter change will be on the cards in the next month or two!
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
You'd need to use an EAS module to alter the standard ride height to be the same as off road, I think.
That sounds cool! Although I want standard height to be standard, but if it has multiple settings that should be fine.
If you know Stuart then give him a call for your Sport and mention my name, he'll see you right with anything you need sorting |
Thanks MikeS, as ever!
