Home > Technical > Parking Brake Squeal |
Strathearn Engineering Member Since: 23 Mar 2012 Location: Aberuthven PH3 1HE Posts: 65 |
Very common, more than likely a strip, clean and adjust Strathearn Engineering
Mon May 07 2012 3:24pm |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
As Strathearn say, very common.
Mon May 07 2012 4:37pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
bloody bag of |
Mon May 07 2012 5:02pm |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
Sister had it on hers a few months back, sounded horrendous but as said, clean and adjust was all that was required.
Mon May 07 2012 7:21pm |
if you keep using it whilst it is squealing, it will break the actuator itself, so more expensive than doing some maintenance instead....
Tue May 08 2012 2:19pm |
LR warranty so ill just need to get it in, stopped usng it in the mean time. |
Wed May 09 2012 11:06am |
they'll most likely say it needs maintenance which isn't warranty... Bodsys Brake Bible
Thu May 10 2012 1:05pm |
after 30k, good luck to them trying to argue that one with me. |
Thu May 10 2012 2:35pm |
JasV6HSE Member Since: 06 Aug 2010 Location: Notts Posts: 56 |
I've had to have mine "cleaned" twice after the dreaded squeal noise starts, neither time could it be done under warranty. ONE hours labour charge each time, but perfect afterwards. |
Thu May 10 2012 3:41pm |
