![]() | Home > General > Tuning with water injection |
Pure gimmic
iainp100 Member Since: 05 May 2011 Location: saddleworth Posts: 59 ![]() ![]() |
Yep i have got that fitted already using the bas remap kit great in can turn it down when i think it is slow then realize how much of a differnece it is with the performance map fitted then the grin is back again Range rover Sport tdv8 with bas touch
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
I had an Impreza STI with the intercooler water spray, only used it once, didn't see the point.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Only any use if you are blasting down the Col de Turini, bouncing off the rev limiter in every gear and your engine bay is hotter that a hot thing!!, just too damn cold in the uk to make a difference
c76jon Member Since: 24 Dec 2008 Location: midlands Posts: 70 ![]() ![]() |
Two different things to be honest.
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 ![]() ![]() |
What results will you get with BOTH a remap and the system though? I also had the STi with water injectors onto the intercooler and didn't notice the value. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
