Home > Maintenance & Modifications > Help, water in driver's footwell without a sunroof !
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Morning all
I have just noticed that my driver's footwell is more like a water well! I know you can get this kind of problem with a RRS fitted with a sunroof but mine doesn't have one. Any help appreciated Rolling Eyes
Post #342973 Wed May 09 2012 8:07am
Leaking aircon or damaged to the underside Question
Try and get the carpets up as soon as possible to get them dried out what ever you do. Thumbs Up ON THE WAY: BMW F21 M140i
Post #342977 Wed May 09 2012 8:25am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
I had the same in one of my previous cars.
Can be that the plastic collector reservoir is clogged, which causes the water to overflow in to the cabin ventilation system.
It collects the water comming from the windshield, preventing it to go down the engine bay.
This gets clogged after years and the reservoir needs to be cleaned of leaves from the trees and other stuff.
The drain holes of the reseroir, releasing the water down on the road, are most of the time also clogged.
Easy job, bring a thin stick.
Good luck! Thumbs Up SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #342979 Wed May 09 2012 8:35am
1JBS
Thanks for your suggestions, but I'm still stuggling to find the source of the water coming into the footwell. Any more ideas would be greatly appreciated Thumbs Up
Post #343116 Wed May 09 2012 10:04pm
ngins
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Hi. Did you ever fix this? I have the same problem which I think is causing the wiring loom to fail on the driver's side as the loom is underwater....... MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #510411 Sun Nov 20 2016 11:55am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Re: Help, water in driver's footwell without a sunroof !
Hi, just to start in the right direction , had it been raining or hose pipe on the roof after washing ?? if it had then it will almost be certain that it is the slots behind the A pillar cover. I had this on mine and i believe it is a very common problem, but an easy fix if it is. Thumbs Up
I have just noticed that my driver's footwell is more like a water well! I know you can get this kind of problem with a RRS fitted with a sunroof but mine doesn't have one. Any help appreciated Rolling Eyes[/quote] 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #510428 Sun Nov 20 2016 5:41pm
Paddi
As suggested - quite likely the 'A' Pillar leak issue. If you follow this link it is to a document (pdf) with all the information you need.
http://www.rrsport.co.uk/gallery/albums/us...0pdf~0.pdf 2008 MY Java Black TDV8 HSE
Post #510433 Sun Nov 20 2016 6:21pm
Eaters
What ever you do I suggest you fix it quick as water and wiring don't mix. Recent CAR SOS programme showed what happened to a Porsche when its seat electrics got wet. Not a pretty site inside. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #510434 Sun Nov 20 2016 6:29pm
ngins
Thanks all for the info and link. Actually my seat has decided to stop working which led me to lift the trim under the door kick panel which led me to discover the water. Dried it out completely Friday and with rain on Saturday it was full of water again today so will get a kit and see if that fixes it. Then only the seat electrics to try and fix........ MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #510441 Sun Nov 20 2016 7:42pm
